    SOLVED How to set exposure for IMX-287M?
    Raspberry Pi App Software
    • E
      etale_cohomology last edited by etale_cohomology
      How do I set the exposure for the IMX-287M?
      I don't find anything about exposure here: https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi
      I also tried:
      v4l2-ctl --set-ctrl exposure=10000 -d /dev/v4l-subdev2
      but it says:
      unknown control 'exposure'
      Maybe there's a media-ctl command?
      I'm on the Raspberry Pi 5 on Bookworm with kernel 6.1.0-rpi7-rpi-2712
        veye_xumm @etale_cohomology last edited by
        @etale_cohomology
        We use an i2c script to configure the camera parameters, including exposure mode and settings. Please refer to the following link:
        • E
          etale_cohomology @veye_xumm last edited by etale_cohomology
          Thank you for your reply.
          I'm using the files here:
          https://github.com/veyeimaging/mvcam_raspberrypi/tree/392451009cc93cfd56bd3c0096c329e7a429f6f8/mv_tools_rpi
          and, according to the docs, before running mv_mipi_i2c.sh I must run
          ./enable_i2c_vc.sh
          ./camera_i2c_config
          but ./camera_i2c_config is failing with:
          setting GPIO for board revsion: d04170
          Failed: don't know how to set GPIO for this board! Type is 17
          (I'm running a Raspberry Pi 5.)
          I also tried the files here: https://github.com/veyeimaging/raspberrypi_v4l2/tree/c782fc464d76c5ed2a7f8f31df72eaaa51e0dceb/mv_tools_rpi
          but same error.
          veye_xumm E 2 Replies Last reply Reply Quote 0
            @etale_cohomology
            Sorry for not being clear, v4l2 mode does not need to execute camera_i2c_config
            • E
              etale_cohomology @etale_cohomology last edited by etale_cohomology
              @etale_cohomology
              I think something is still missing, because I still can't run ./mv_mipi_i2c.sh successfully.
              For example,
              ./mv_mipi_i2c.sh -r -f manufacturer
              returns
              Manufacturer 0 not recognized
              ./mv_mipi_i2c.sh -r -f model
              returns
              model 0 not recognized
              EDIT
              It turns out you must manually select the I2C bus number (I also enabled I2C on raspi-config). Since I'm using CAM0 on RPI5, the bus is 6. Example:
              ./mv_mipi_i2c.sh -r -f manufacturer -b 6
              This works.
                @etale_cohomology said in How to set exposure for IMX-287M?:
                This works.
                Yes
