    SOLVED MV-MIPI-GMAX4002M compatibility with Jetson Xavier NX, Orin NX
    Machine Vision camera
    2906
    • S
      STiwana last edited by
      I am considering using VEYE cameras in a product line. Before I buy, I just want to clarify few things:
      1. Can you confirm that MV-MIPI-GMAX4002M camera is supported by Jetson Jetpack 5.1 and 6.2? I ask because this camera is not listed on the wiki page:
        https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_jetson
      2. I would prefer to get the adapter with the 22 pin RPi interface, which I believe is the ADP-MV1-V2 board. However, I don't see a purchase link. On the Aliexpress page for MV-MIPI-GMAX4002M, it is not clear if it ships with the ADP-MV1-V2 or ADP-MV1 version adapter.
      3. On the Aliexpress page for MV-MIPI-GMAX4002M camera ( https://vi.aliexpress.com/item/1005008643965893.html? ) if I choose the GMAX4002M ADP-MV1 variant, does it ship with the ADP-MV1-V2 variant of the adapter board? Also, is the C mount adapter included or do I need to buy separately?
      4. Is there any issue or limitation I need to be aware of when using the MV-MIPI-GMAX4002M with Jetson Xavier NX and Jetson Orin NX? My application requires use in Freerunning and triggered modes, with using ROIs, and my application requires high frame rate (~200fps or more).
      5. To me, this camera seems the best in high low-light sensitivity (big pixel size!). Is this a correct assumption among the Machine Vision or Raw series cameras?
      6. What is the main difference between the MV series and RAW series cameras? I couldn't figure out the differences.
      Sorry for the very long questions...I just want to make sure the camera fits my needs before I do any purchase.
      Thansk and Best Regards,
      Saad
        veye_xumm @STiwana last edited by veye_xumm
        @stiwana
        1. The MV-MIPI-GMAX4002M model was missing on this page and has now been added. Both Jetpack 5.1 and 6.2 are supported. However, we currently only provide the 4-lane mode DTB for Orin NX and Orin Nano under JP6.2 mode, as only these two boards have official baseboards that expose the 4-lane interface.
        2. You're right. Just place the order using that link. We will ship ADP-MV1-V2.
        3. For Jetson Xavier NX, since the official baseboard only exposes 2 lanes, the DTB in our provided driver remains configured for 2-lane mode, which limits the maximum frame rate.
          As for Orin NX, there is no such restriction. You can refer to the 4 How to Use 4-Lane Modesection to enable 4-lane mode.
        4. yes.
        5. The MV series products feature ISP (Image Signal Processor) capabilities, including typical functions such as auto-exposure, LUT (Look-Up Table), and more.
        • N
          newstec @veye_xumm last edited by
          I purchased the MV-MIPI-GMAX4002M with the ADP-MV1-V2 adapter. I installed the Jetpack6.2,L4T r36.4.3 on the Jetson Orin NX 8gb. However, unfortunately I cannot install it using the GitHub repository "nvidia_jetson_veye_bsp". How can I proceed with the installation? Thank you very much!
            veye_xumm @newstec last edited by
            @newstec
            https://wiki.veye.cc/index.php/How_to_upgrade_the_Jetson_system_to_support_VEYE_cameras
            Please refer to this article, mainly part 6.6, part 6.8, and part 8.
            • N
              Thank you very much for the reply, it really helped! I followed the recommendations faithfully and successfully completed the installation. However, I'm facing a problem:
              The camera generates an image with errors and very low fps, as shown in the attached image:
              Attached is the sudo dmesg: ubuntu@ubuntu~$ sudo dmesg.txt
              ubuntu@ubuntu:~$ sudo dmesg | grep -i 'fail'
              [  779.319935] mvcam 10-003b: camera_common_s_power: failed to enable mclk
              [ 2254.006074] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
              [ 2334.553992] mvcam 10-003b: camera_common_s_power: failed to enable mclk
              [ 3210.855067] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
              ubuntu@ubuntu:~$ sudo i2cdetect -y -r 9
              70: -- -- -- -- -- -- -- --
              ubuntu@ubuntu:~$ sudo i2cdetect -y -r 10
              ubuntu@ubuntu:~$ ls /sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@0/
              '#address-cells'   rbpcv2_imx219_a@10   reg            status
               name              rbpcv3_mvcam_a@3b   '#size-cells'
              ubuntu@ubuntu:~$ ls /sys/bus/i2c/drivers/
              ubuntu@ubuntu:~$ v4l2-ctl --list-formats-ext
              ioctl: VIDIOC_ENUM_FMT
              	Type: Video Capture
              	[0]: 'GREY' (8-bit Greyscale)
              		Size: Discrete 2048x1200
              			Interval: Discrete 0.037s (27.000 fps)
              ubuntu@ubuntu:~/Downloads/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ sudo ./mv_mipi_i2c.sh -r -f version -b 10
              [sudo] password for ubuntu:
              Executing: ./mv_mipi_i2c_new.sh -r version -b 10
              version is C 01.48 and L 03.20
              TIMEOUT 30
              DEFAULT primary
              MENU TITLE L4T boot options
              LABEL primary
                    MENU LABEL primary kernel
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    APPEND ${cbootargs} root=PARTUUID=e7cecac7-8b18-4414-b9b9-41ae8eab84d9 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
                    FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
                    OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veye_mvcam-dual-4lane-cam1.dtbo
              # When testing a custom kernel, it is recommended that you create a backup of
              # the original kernel and add a new entry to this file so that the device can
              # fallback to the original kernel. To do this:
              # 1, Make a backup of the original kernel
              #      sudo cp /boot/Image /boot/Image.backup
              # 2, Copy your custom kernel into /boot/Image
              # 3, Uncomment below menu setting lines for the original kernel
              # 4, Reboot
              # LABEL backup
              #    MENU LABEL backup kernel
              #    LINUX /boot/Image.backup
              #    INITRD /boot/initrd
              #    APPEND ${cbootargs}
              I only have one camera.
              I'd be very happy if it worked well! Thank you very much.
                @newstec
                Please try veye_viewer.
                https://github.com/veyeimaging/veye_viewer/releases/tag/v0.1.1_jetson
                • N
                  Thanks for all the help!
                  • N
                    newstec @newstec last edited by
                    @veye_xumm Good news, it's working!
                    I changed the port to "CAM1" (i2c-9).
                    I believe the "v0.1.1_jetson" files were essential for proper operation.
                    Thank you for your efforts in helping.
                      @newstec Cheers!
                      • S
                        Hi @veye_xumm
                        I have an application that needs a very low latency (<10ms at maximum. Even less if possible) from capture to being available to the Jetson for real-tim processing. I read in some posts on the forum that veye cameras have more than 100ms latency due to ISP. In that case, is there any VEYE camera that I can still use? My requirements are:
                        • Bigger pixel size for low light capture (the GMAX4002 seemed decent)
                        • High frame rate (at least more than 60fps)
                        • Ability to use a physical trigger signal
                        • Very low latency (<10ms, even less if possible).
                        Please guide me if there are any VEYE cameras which will satisfy my requirements. Thank you.
                          @stiwana
                          I think the post on the forum might have misled you. In fact, the latency of the VEYE series (models starting with VEYE-) is relatively high.
                          The latency of the MV series, for instance MV-MIPI-GAMX4002M, is very low (below 1ms) because our ISP pipeline does not use frame buffering and only has a small amount of line buffering.
                          • S
                            STiwana @veye_xumm last edited by
                            Thanks so much for your answer. I am very glad I asked you this question. Of the latency is 1ms as you mention , then the rest looks suitable too. I will buy some to test.
                            Some follow up question:
                            1. With the MV-MIPI-GMAX4002 camera on Jetson, can I also use the camera inside a gstreamer pipeline (and also maintain the low latency)?
                            2. For the lowest latency and deterministic performance (the application will need to know exactly when the frame was acquired), what would you suggest with these cameras...use from opencv or gstreamer, or does it not matter? Any other tips you can give me for very low latency, real time performance with the MV cameras?
                            3. What's the usual lead time to buy these cameras in case the cameras are out of stock when purchasing (from a supply chain point of view when my device is in production)
                            4. How many years do you plan to keep these camera modules available for?
                            Best Regards
                              @stiwana
                              For specific information, please refer to the link above. We provide a veye_viewer client for customers to initially get started and verify usage.
                              We haven't done extensive debugging on GStreamer yet. As for OpenCV, there are examples provided in the article above. Regarding the latency issue: although the camera itself has negligible delay, each image entering the Jetson system will experience some latency due to the V4L2 buffer, format conversion, and preview processes—all of which involve memory buffering queues.
                              The most fundamental solution is to develop your own program tailored to your product's specific needs, allowing flexible management of buffers. Additionally, note that the V4L2 buffer containing the camera images after they enter the Jetson system includes timestamps. It is recommended that you use these timestamps.
                              Regarding the supply of this product, we will maintain long-term availability unless the chip is discontinued. We will keep a regular inventory sufficient to meet retail demand. For bulk orders of several hundred units or more, the production cycle is typically within one month.
                              • S
                                STiwana last edited by STiwana
                                Hi @veye_xumm
                                I purchased the MV-MIPI-GMAX4002 camera with ADP-MV1-V2 adapter.
                                My setup is Jetson Xavier NX 8GB developer kit running nvidia-l4t-core 35.6.1.
                                I documented my "installation" process on the Jetson as following:
                                *** Get latest veye BSP:
                                wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tar.gz
                                tar -xzvf nvidia_jetson_veye_bsp.tar.gz
                                cd nvidia_jetson_veye_bsp/
                                *** Find and extract the correct kernel image (mine is l4t_r35.6)
                                cd kernel_image/
                                tar -xzvf Image_l4t_r35.6_mvcam_patched_signed_4_xavier_orin.tgz
                                *** Make a backup of Old boot Image:
                                sudo cp /boot/extlinux/extlinux.conf /boot/extlinux/extlinux.conf.backup
                                *** Copy Image files from extracted image folder to boot folder:
                                sudo cp Image/Image /boot/
                                sudo cp Image/Image.sig /boot/
                                *** Go back to main BSP extracted folder:
                                cd ..
                                *** Copy camera drivers (Jetpack 5.x)
                                sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/* /lib/modules/$(uname -r)/kernel/drivers/media/i2c/ -f
                                *** Register the modules into the system:
                                sudo depmod
                                *** Copy the New Device Tree Blob (DTB) for MV cameras, my board (Xavier NX 8GB dev kit)
                                sudo cp dtbs/Xavier-NX/JetPack_5.1.4_Linux_JETSON_XAVIER_NX_TARGETS/dts\ dtb/MV-MIPI-CAM/tegra194-p3668-0000-p3509-0000.dtb /boot/
                                *** Update the bootloader CONFIGURATION
                                sudo nano /boot/extlinux/extlinux.conf
                                *** I copied the last configuration and modified it with name of my dtb file manually as following:
                                LABEL VeyeIO
                                MENU LABEL Custom Header Config: <VEYE MV-CAM Dual>
                                LINUX /boot/Image
                                FDT /boot/tegra194-p3668-0000-p3509-0000.dtb
                                INITRD /boot/initrd
                                APPEND ${cbootargs} root=PARTUUID=4210ce41-79b8-4264-8716-c03322463d38 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off nospectre_bhb nv
                                -auto-config
                                *** Then I pasted(appended) it to end of the .conf file
                                *** I also changed the second line in file to set new config as default:
                                DEFAULT VeyeIO
                                *** Reboot board:
                                sudo reboot
                                After this i powered off the Jetson, and connected the camera to the MIPI port, taking care of the MIPI cable directions (I took pictures..I will upload later from the phone). I also connected the 5V from the Jetson Xavier NX(pin4 for 5V, pin 6 for GND) to the ADP-MV1-V2 board. Anyway, after powering on the Jetson, I don't see any sign of the camera either with ls /dev/vid* or even if i do: sudo dmesg | grep "veye"
                                Can you give me some pointers where I may be going wrong??
                                  @stiwana
                                  Please refer to the section below, part 8, for checking. Additionally, run sudo dmesg | grep mvcam to see if there is any output.
                                  https://wiki.veye.cc/index.php/How_to_upgrade_the_Jetson_system_to_support_VEYE_cameras#Are_Image_and_DTB_upgrade_successful_.3F
                                  • S
                                    Hi @veye_xumm ,
                                    Thank you for all your help, I was able to get the camera to work. I have some follow up questions:
                                    1. Can I use the commonly available RPi-zero Mipi camera FPC to connect the camera to Jetson Orin NX? Currently, I am using the (22pin-to 15pin) cable that came with the camera, but I need bit more distance between the camera and Jetson. I am wondering if I can use the commonly available RPi 22pin-to-15pin CSI cables of if the camera configuration on your camera is different. Mine came with ADP-MV1-V2.
                                    2. I need to get the best low light performance possible (the most important point is that a human observer can see more things, even if image is noisy). After experimenting, so far I have come up with the following for my "night mode":
                                    ****** Low light night time auto settings ****
                                    ./mv_mipi_i2c_new.sh -w fps 15 -b 2 -> Can't be done while in acquisition
                                    ./mv_mipi_i2c_new.sh -w gammaenable 1 -b 2
                                    ./mv_mipi_i2c_new.sh -w aemaxtime 500000 -b 2
                                    • Following so that gain stays maximum and auto function only reduces exposure time
                                    • If not, the default algo will reduce gain first, then exposure time (not best for fast moving objs?)
                                      ./mv_mipi_i2c_new.sh -w gainmode 0 -b 2
                                      ./mv_mipi_i2c_new.sh -w mgain 24 -b 2
                                    • Now we can set the exposure quality by changing just one parameter (can be changed on the fly - 40 seems
                                    • a good all around value at night for dark n bright situations)
                                    • Adapts well to changes in lighting and doesn't over expose in ample light, while still giving max gain in dark
                                    • Since gain stays fixed at 25db (noisier), it should only be used in night time
                                      ./mv_mipi_i2c_new.sh -w aatarget 40 -b 2
                                    My question: Is there anything else I can do to increase the low-light performance? Did i miss another setting that can help?
                                    1. I do notice that at higher gain the images get these fixed patterns probably due to the FPNU or PRNU of pixel array. Is there a way to do a calibration on the image sensor to make the image response more uniform?
                                    2. Is there any gstreamer pipeline I can use to get 12 bit image stream out and display it as 8bit in real time?
                                    Best Regards
                                      @stiwana
                                      @stiwana said in MV-MIPI-GMAX4002M compatibility with Jetson Xavier NX, Orin NX:
                                      Yes.
                                      To improve performance in low-light conditions, the main methods are:
                                      1. Use a lens with a smaller F-number.
                                      2. In either automatic or manual exposure mode, extend the exposure time to the maximum duration you can tolerate. (Note that the exposure time cannot exceed the reciprocal of the frame rate, so you may need to adjust it accordingly based on your specific situation.)
                                      3. Increase the gain.
                                      Sorry, we don't offer this algorithm yet.
                                      Sorry, we don't provide this kind of program either.
