    Install camera to rpi4
    14 Posts 3 Posters 5.0k Views 1 Watching
    • V Offline
      Viktor @veye_xumm
      • V Offline
        Viktor @Viktor
        Here is rpi boot contents:
        number@number:/boot$ ls
        config-5.11.0-1008-raspi  dtb-5.11.0-1008-raspi  grub
        System.map-5.11.0-1008-raspi
        config.txt
        dtbs
        initrd.img
        vmlinuz-5.11.0-1008-raspi
        dtb
        firmware
        initrd.img-5.11.0-1008-raspi
        • V Offline
          Viktor @Viktor
          I tried installing veye327 to rpiOs.
          I have 5.10.36 firmware. veye drivers don't have this version.
          I tried build from source, but failed.
          Copied built zImage and veye327.dtbo to rpi and got load kernel modules failed on startup.
          Updated: i did modules_install and veye327 works on rpiOs now.
          Can you help build kernel for Ubuntu Desktop Rpi?
          • V Offline
            Viktor @Viktor
            I did it.
            crosscompile kinux image veye327 driver for Ubuntu Desktop 21.04 Rpi4
            on rpi4
            uname -r
            5.11.0-1008-raspi
            uname -a
            Linux number 5.11.0-1008-raspi #8-Ubuntu SMP PREEMPT Thu May 6 17:46:38 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
            on host
            sudo apt install git bc bison flex libssl-dev make libc6-dev libncurses5-dev crossbuild-essential-arm64
            mkdir rpi_ubuntu_source
            cd rpi_ubuntu_source
            git clone --depth=1 git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux-raspi/+git/hirsute linux
            git clone https://github.com/veyeimaging/raspberrypi_v4l2.git
            cp raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.x_all/veye327.c linux/drivers/media/i2c
            edit linux/drivers/media/i2c/Kconfig
            find section imx219 and after it add:
            config VIDEO_VEYE327
            	tristate "VEYE VEYE327 sensor support"
            	depends on I2C && VIDEO_V4L2
            	select MEDIA_CONTROLLER
            	select VIDEO_V4L2_SUBDEV_API
            	select V4L2_FWNODE
            	help
            	  This is a Video4Linux2 sensor driver for the VEYE
            	  IMX327 camera.
            	  To compile this driver as a module, choose M here: the
            	  module will be called veye327.
            edit linux/drivers/media/i2c/Makefile
            find line imx219 and after it add:
            obj-$(CONFIG_VIDEO_VEYE327)	+= veye327.o
            cp raspberrypi_v4l2/driver_source/dts/rpi-5.10.y/veye327-overlay.dts linux/arch/arm64/boot/dts/overlays
            edit linux/arch/arm64/boot/dts/overlays/Makefile
            veye327.dtbo \
            build kernel
            cd linux
            KERNEL=kernel8
            make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- bcm2711_defconfig
            make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- menuconfig
            go to Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices
            select veye327 and save
            make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- Image modules dtbs -j4
            mount sd to host
            mkdir mnt
            mkdir mnt/fat32
            mkdir mnt/ext4
            sudo mount /dev/sdd1 mnt/fat32
            sudo mount /dev/sdd2 mnt/ext4
            copy modules
            sudo env PATH=$PATH make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- INSTALL_MOD_PATH=mnt/ext4 modules_install
            copy kernel and dtb
            sudo cp mnt/fat32/vmlinuz mnt/fat32/vmlinuz.old
            sudo cp arch/arm64/boot/Image mnt/fat32/vmlinuz
            sudo cp arch/arm64/boot/dts/broadcom/*.dtb mnt/fat32/
            sudo cp arch/arm64/boot/dts/overlays/*.dtb* mnt/fat32/overlays/
            sudo cp arch/arm64/boot/dts/overlays/README mnt/fat32/overlays/
            sudo umount mnt/fat32
            sudo umount mnt/ext4
            on rpi4
            edit /boot/firmware/config.txt
            add lines
            gpu_mem=400
            dtparam=i2c_vc=on
            cma=128M
            dtoverlay=veye327.dtbo
            start_x=1
            sudo reboot
            dmesg | grep veye
            veye327 probed
            preview
            gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! autovideosink sync=false text-overlay=false -v
            success
            V F 2 Replies Last reply Reply Quote 0
            • V Offline
              Viktor @Viktor
              Add to /etc/modules
              i2c-dev
              i2c bus 10,11 for sensor control
                veye_xumm @Viktor
                @viktor
                Great! Thank you for trying and sharing.
                • V Offline
                  Viktor @veye_xumm
                  • F Offline
                    fire @Viktor
                    @viktor
                    Thanks very much.
                    I wonder how did you set camera parameters, I found that the cs_mipi_i2c.sh not working.
                    • V Offline
                      Viktor @fire
                      @fire Veye327 i2c fully works.
                      • F Offline
                        fire @Viktor
                        @viktor
                        Can you use the original pi commands (e.g. raspistill raspivid), instead of using gst-launch?
                        • V Offline
                          Viktor @fire
                          @fire Yes, raspivid and raspistill works too on Ubuntu.
