VEYE imx385 驱动问题+
VEYE MIPI在 roc3588s-pc的板子,直接刷了 您提供的最新的
好像不太对,我DMESG是 这样,是不是需要我在firefly 重新编译到最新的linux系统里面,这个版本 已经不支持VEYE系列了
parsed
[ 6.876879] veye_vbyone 7-0065: thcv242a_init_pre: begin
[ 6.877028] veye_vbyone 7-0065: Cannot write register 0x50 (-6)!
[ 6.877170] veye_vbyone 7-0065: Cannot write register 0x04 (-6)!
[ 6.877313] veye_vbyone 7-0065: Cannot write register 0x10 (-6)!
[ 6.877455] veye_vbyone 7-0065: Cannot write register 0x1704 (-6)!
[ 6.877597] veye_vbyone 7-0065: Cannot write register 0x102 (-6)!
[ 6.877739] veye_vbyone 7-0065: Cannot write register 0x103 (-6)!
[ 6.877881] veye_vbyone 7-0065: Cannot write register 0x104 (-6)!
[ 6.878023] veye_vbyone 7-0065: Cannot write register 0x105 (-6)!
[ 6.878165] veye_vbyone 7-0065: Cannot write register 0x100 (-6)!
[ 6.878307] veye_vbyone 7-0065: Cannot write register 0x10f (-6)!
[ 6.878453] veye_vbyone 7-0065: Cannot write register 0x10a (-6)!
[ 6.878598] veye_vbyone 7-0065: Cannot write register 0x31 (-6)!
[ 6.878602] veye_vbyone 7-0065: thcv242a_init_pre: successfully
[ 6.878605] veye_vbyone 7-0065: thcv242a_probe: error initializing thcv242a pre
[ 7.040169] mvcam 7-003b: veye mv series camera driver version: 01.01.08 -
@flaty
您这个截图的镜像是MV和RAW系列的。
请参考这个链接中的镜像。
https://github.com/veyeimaging/rk35xx_firefly/releases/tag/v1.7 -
@veye_xumm 我也得觉得不对,IMX385 veye系列的最新的驱动是哪个,是1.7下的吗
@flaty 驱动源码你直接用github最新的就行。
@veye_xumm 编译错误 我把信息发给您看一下,是驱动里面的结构体
CC drivers/media/i2c/veyecam2m.o
drivers/media/i2c/veyecam2m.c: In function 'veyecam2m_g_mbus_config':
drivers/media/i2c/veyecam2m.c:419:24: error: 'V4L2_MBUS_CSI2' undeclared (first use in this function); did you mean 'V4L2_MBUS_CSI1'?
419 | config->type = V4L2_MBUS_CSI2;
| V4L2_MBUS_CSI1
drivers/media/i2c/veyecam2m.c:419:24: note: each undeclared identifier is reported only once for each function it appears in
drivers/media/i2c/veyecam2m.c: At top level:
drivers/media/i2c/veyecam2m.c:898:3: error: 'const struct v4l2_subdev_video_ops' has no member named 'g_mbus_config'
898 | .g_mbus_config = veyecam2m_g_mbus_config,
drivers/media/i2c/veyecam2m.c:898:19: error: initialization of 'int (*)(struct v4l2_subdev *, struct v4l2_subdev_frame_interval )' from incompatible pointer type 'int ()(struct v4l2_subdev *, struct v4l2_mbus_config *)' [-Werror=incompatible-pointer-types]
drivers/media/i2c/veyecam2m.c:898:19: note: (near initialization for 'veyecam2m_video_ops.s_frame_interval')
cc1: all warnings being treated as errors
make[4]: *** [scripts/Makefile.build:273:drivers/media/i2c/veyecam2m.o] 错误 1一下是内核配置
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =rockchip_linux_defconfig
TARGET_KERNEL_DTS =roc-rk3588s-pc-mipi101-BSD1218-A101KL68
TARGET_KERNEL_CONFIG_FRAGMENT =rk3588_linux.config firefly-linux.config -
[0_1756784079945_log.zip](正在上传 100%) 这个是完整的编译log,您看一下,我使用firefly最新的SDK 进行的编译,采用5.10的内核
@flaty
参见代码的注释,你的内核缺少这个接口,需要注掉这个函数。
@veye_xumm 您这边 适配过 SDK1.4.0G 这个版本吗 firefly
@flaty 可以的。
@flaty 就是这个。
@veye_xumm zhge dsi的头您看 有问题吗 检测不到相机,
#include "roc-rk3588s-pc.dtsi"//#include "rk3588-roc-pc-cam-8ms1m.dtsi"
//open this line to enable fpdlink-III link
//#include "rk3588-roc-pc-fpdlink-90ub954.dtsi"//open this line to enable v-by-one hs link
#include "rk3588-roc-pc-vbyone-overlay.dtsi"#include "rk3588-roc-pc-cam-veyecam2m.dtsi"
#include "rk3588-roc-pc-cam-veyemvcam.dtsi"#include "roc-rk3588s-pc-v10-diff.dtsi"
#define WHICHDSI 0 /* dsi0 = 0,dsi1 = 1*/ -
