    UNSOLVED MV-MIPI-SC130M autoexposure problem
    Machine Vision camera
    4100
    • D
      Dan last edited by
      I am using MV-MIPI-SC130M camera with RK3588S basic image from VEYE.
      Camera is configured used to hardware trigger mode on rising edge, aemaxexposure time is 5000 mks.
      Sometimes after restarts autoexposure mode does not work, current exposure time is near 4600 - 4800 ms and does not changes, even if I change aemaxexposure value.
      After restart autoexposure works normally.
        veye_xumm @Dan last edited by
        @dan
        Generally, in external trigger mode, manual exposure is recommended.
        This is because the algorithm of the automatic exposure mode relies on regular image input, whereas the trigger intervals in external trigger mode may be random or even very long.
        If the ambient lighting in your application scenario is stable, it is still advisable to use manual exposure mode.
        • D
          Dan @veye_xumm last edited by
          We use regular external trigger, target framerate is 20 fps. Ambient lighting not stable, so we have to use autoexposure mode.
            @dan Please read the version number of the camera you are using and send it to me.
            • D
              version is C 01.35 and L 02.01
                @dan
                Please refer to the two links below to upgrade the firmware of your camera. Then test it again.
                https://wiki.veye.cc/index.php/Mvcam_firmware_update_manual
                https://wiki.veye.cc/index.php/MV-MIPI-SC130M_Version_Log
                • D
                  Thank you, I take a some time for tests
                  • D
                    @veye_xumm Hi,
                    Firmware update does not solve the problem, after software reset auto exposure mode works normal
