    SOLVED Veye MIPI imx462 Defaults
    • N
      nimadibaj last edited by
      What is the default config of veye mipi 462 ?
      UYVU or YUYV ?
      25 fps or 30 fps ?
      HS mode and LP mode?
      Thanks.
      • N
        nimadibaj @nimadibaj last edited by
        @nimadibaj
        We are analyzing the output signal. It seems that between each video line, the CSI-2 output from your module enters Low-Power (LP) mode, which causes the video stream to continuously drop in and out. The module is completely new, and we have not sent any I²C commands to it. It appears that the module should operate in High-Speed (HS) mode, but it does not.
          veye_xumm @nimadibaj last edited by
          @nimadibaj
          UYVY 30fps
          @nimadibaj said in Veye MIPI imx462 Defaults:
          This complies with the MIPI CSI-2 standard.
