    Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    29 Posts 2 Posters 15.1k Views 1 Watching
    • J Offline
      jambojettt @veye_xumm
      @veye_xumm this didn't work, I updated the raspi-config to the latest one, this command didn't work. Tried this several times to no avail.
      • J Offline
        jambojettt @jambojettt
          veye_xumm @jambojettt
          @jambojettt
          Sorry for the slightly delayed reply. Normally, piOS comes with kernel-headers pre-installed. For example, here is a screenshot of my current system:
          I suspect that you might have updated to a newer minor version of piOS, which caused this issue. The current major version of piOS should be 6.12.47.
            • J Offline
              @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
              How do I get the headers?
                @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
                My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
                • J Offline
                  • J Offline
                    Kernel headers are installed.
                    • J Offline
                        @jambojettt
                        uname -a
                        ls /usr/lib/modules/
                        • J Offline
                            @jambojettt
                            Sorry for reply late.
                            • J Offline
                              make
                              reinstalled by github
                              Which one do I use?
                                @jambojettt
                                • J Offline
                                    @jambojettt
                                    dmesg | grep veye
                                    • J Offline
                                      @veye_xumm nothing showed
                                      • J Offline
                                        @veye_xumm is there any point in a fresh pi os install?
                                        I accidentally swapped the pins after I checked everything, and it shorted, hope it works.
                                        I just need it to work, so I can do my thesis on argicultural application of machine learning.
                                        • J Offline
                                          Everything is the same
                                          • J Offline
                                            @veye_xumm a926f7d9-25bb-40db-bc6d-d6136c0cddd9-изображение.png fc72b201-eabf-40b3-81b9-de8a99077f4b-изображение.png !438d2092-5f6a-460e-b2b2-438605356263-изображение.png [0_1764333202538_7825037f-a24a-4cbf-b16b-42693c1e5a87-изображение.png](Uploading 100%)
                                            I'm out of possible problems, maybe i got the pins wrong.8c38bbeb-7f2c-423a-bb4c-546227c6c1ea-изображение.png
