    Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    29 Posts 2 Posters 15.8k Views 1 Watching
      veye_xumm @jambojettt
      @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
      @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
      How do I get the headers?
      My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
      • J Offline
        jambojettt @veye_xumm
        • J Offline
          jambojettt @jambojettt
          Kernel headers are installed.
          • J Offline
              @jambojettt
              uname -a
              ls /usr/lib/modules/
              • J Offline
                  @jambojettt
                  Sorry for reply late.
                  • J Offline
                    make
                    reinstalled by github
                    Which one do I use?
                      @jambojettt
                      • J Offline
                          @jambojettt
                          dmesg | grep veye
                          • J Offline
                            @veye_xumm nothing showed
                            • J Offline
                              @veye_xumm is there any point in a fresh pi os install?
                              I accidentally swapped the pins after I checked everything, and it shorted, hope it works.
                              I just need it to work, so I can do my thesis on argicultural application of machine learning.
                              • J Offline
                                Everything is the same
                                • J Offline
                                  @veye_xumm a926f7d9-25bb-40db-bc6d-d6136c0cddd9-изображение.png fc72b201-eabf-40b3-81b9-de8a99077f4b-изображение.png !438d2092-5f6a-460e-b2b2-438605356263-изображение.png [0_1764333202538_7825037f-a24a-4cbf-b16b-42693c1e5a87-изображение.png](Uploading 100%)
                                  I'm out of possible problems, maybe i got the pins wrong.8c38bbeb-7f2c-423a-bb4c-546227c6c1ea-изображение.png
                                  • J Offline
                                      @jambojettt
                                      I suspect you haven't seen the most important document, which is the link below. Generally, you don't need to compile the driver yourself. Instead, you can simply install the driver by following part4 in the link below. Specifically, the command you need to execute is: sudo ./install_driver.sh veyecam2m
                                      https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi#Driver_Installation
                                      • J Offline
                                        Before I followed the wiki, then I followed github. Which one is the correct one?00285983-1023-48c2-8985-aa7a10ea3a53-изображение.png
                                          @jambojettt
                                          Sorry for missing veyecam2m.dtbo, please try this new release package.
                                          • J Offline
                                            @veye_xumm it is resolved now, the image is shown. Before with the steps on the forum the .dtbo file was also missing, I copied it from another folder and it didn't work. The right and supported way of installing drivers is very confusing, I tried installing by wiki guide and then compiling locally (github), since it didn't work. Thank you for your patience.
