    GX-MIPI-IMX662 can't save fps parameter
    25 Posts 2 Posters 6.0k Views 1 Watching
      veye_xumm @alex_ai
      @alex_ai In the current program, HCG will be automatically enabled when the gain is higher than 26 dB — you can give it a try.
      Also, please try turning off the 3D noise reduction.
      • A Offline
        alex_ai @veye_xumm
        @veye_xumm yes, you are right, I checked image in 25 and 26 dB - and it is switching.
        Probably I used high digital gain (because brightness low than from IMX462 in same gain value) and it produces high level of noise.
        About denoise, in IMX462 I'm using 0x02, but not sure what is MIDDLE value, because in IMX662 denoise_strength_3D with 128 produces different picture and I decreased to 40 to have something similar
        0x02	NR 2D Mode = OFF; NR 3D Mode = MIDDLE
        Will test couple nights. Thank you.
          veye_xumm @alex_ai
          @alex_ai OK, the GX series and the VEYE series use completely different ISP solutions, so their parameters do not correspond one-to-one. I look forward to your test results.
          • A Offline
            alex_ai @veye_xumm
            @veye_xumm found what was wrong,
            high level of noise produced gamma_index = 1 (default value), other looks good.
              veye_xumm @alex_ai
              @alex_ai Thank you for your feedback; we will look into this issue.
                veye_xumm @alex_ai
                @alex_ai I used firmware version 1.14 for comparison and did not observe any significant noise changes in gamma mode 1 compared to other modes. Could you provide your specific usage parameters and environment?
                • A Offline
                  alex_ai @veye_xumm
                  Hi @veye_xumm, I didn't say that this is issue, this parameter needs to be changed only in case video recording of the night sky (meteor detection)
                  From issues what I noticed:
                  • can't save fps - always 60 after power on
                  • Sometimes saved parameters resets to default (noticed when set metime to 33333 but forgot set fps 30 before) and manual expmode switched back to auto
                  • A Offline
                    alex_ai @veye_xumm
                    Hi @veye_xumm, I'm still trying to configure imx662 for night capturing (meteor detection) and probably you can help me to clarify what is wrong.
                    I have several cameras from VEYE (imx462 and imx462 mono) and also imx662 mono from another vendor.
                    And for all cameras configuration pretty same - use 30fps, exposure time 33333 and gain 30Db for mono version and up to 34Db color version (this range approximately within analog gain).
                    What I see in GX imx662 - for same parameters image too dark, some brightness I can get from gamma_index (with value 5 or 10) but it still not enough
                    To get required brightness of image I have to increase gain to 45 which leads to boost digital gain and as result more noise, more hot pixels and overbrighted (oversized) stars.
                    Questions:
                    1. What could be wrong? (imx662 mono works as expected, not sure it is sensor issue)
                    2. Can I read sensor registors same as on imx462?
                    My current config (Raspberry Pi 5, Trixie) :
                    ./gx_mipi_i2c.sh -w fps 30 -b $i2cBus
                    ./gx_mipi_i2c.sh -w expmode 0 -b $i2cBus
                    ./gx_mipi_i2c.sh -w metime 33333 -b $i2cBus
                    ./gx_mipi_i2c.sh -w mgain 34 -b $i2cBus
                    ./gx_mipi_i2c.sh -w denoise_strength_3D 0 -b $i2cBus
                    ./gx_mipi_i2c.sh -w denoise_strength_2D 0 -b $i2cBus
                    ./gx_mipi_i2c.sh -w sharppen 30 -b $i2cBus
                    ./gx_mipi_i2c.sh -w gamma_index 5 -b $i2cBus
                    ./gx_mipi_i2c.sh -w daynightmode 1 -b $i2cBus
                    Example of image in same time and same parameters (gain 34) for:
                    GX IMX662
                    VEYE IMX462
                      veye_xumm @alex_ai
                      @alex_ai First, let me explain the gain configuration logic for the GX-MIPI-IMX662. The IMX662 features 30dB of Analog Gain and supports High Conversion Gain (HCG). The HCG function acts as an amplification during the sensor's analog signal readout, equivalent to 15.3dB.
                      Therefore, when we configure the "Again" parameter, the actual range is [0, 45.3dB]. This means you can set the Analog Gain up to 45dB without enabling Digital Gain (Dgain).
                      Currently, our firmware integrates HCG into the "Again" setting, which may have caused some confusion during your testing.
                      As for the feature to read sensor registers, I have added it to the development roadmap. It will be provided later via a firmware update package.
                        veye_xumm @alex_ai
                        @alex_ai
                        We recently updated the ISP tuning. Please give it a try.
                        https://wiki.veye.cc/index.php/GX-MIPI-IMX662_Version_Log
                        • A Offline
                          alex_ai @veye_xumm
                          Hi @veye_xumm,
                          Thank you for new update and letting me know!
                          On first look - the original issue was fixed - now I can save fps parameter and we could close this topic.
                          About night sky image, I don't see visible differences and want to play with parameters one more time and monitor camera registers.
                          I see was added new feature:
                          ./gx_mipi_i2c.sh -r snsreg [sensor reg addr] -b your_i2c_bus_number
                          I tried check sensor gain (register 0x3070) but not sure what should be reg address, tried 0x3070 and 0x70 (seems like it is expecting value less than 0x100)
                          if you could provide example - it would be helpful
                            veye_xumm @alex_ai
                            @alex_ai
                            I would recommend using the exptime and curgain functions first to check the current performance of the camera module. If you are familiar with the sensor registers, you can verify the sensor's working status by reading registers 0x3070 and 0x3071.
                            • A Offline
                              alex_ai @veye_xumm
                              @veye_xumm yes, I want to verify camera sensors but this command doesn't work for me, that is why I asked example.
                               $ sudo ./gx_mipi_i2c.sh -r snsreg 0x3070 -b 6
                               Read Sensor Reg 0x3070, val=0xffffffffffffffff
                              Unfortunately, my night sky tests failed:
                              • Without an IR filter, I can't get the stars into focus for some reason—they are always blurry and haloed.
                              • With an IR filter, the stars are in focus but they become extremely dim.
                              I'll probably stick with the old IMX462 sensor for my projects.
                                veye_xumm @alex_ai
                                @alex_ai
                                I'd like to first confirm your firmware version with you. As shown below, everything is working fine on my end.
                                pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r snsreg 0x3070
                                Read Sensor Reg 0x3070, val=0x0
                                pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r snsreg 0x3071
                                Read Sensor Reg 0x3071, val=0x0
                                pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r version
                                Read version is C 01.32 and L 01.19
                                Regarding the image quality during IR-cut switching, may I ask whether you are using the same IR-cut filter for both the IMX662 and the IMX462? Also, could you share some sample images with me?
                                • A Offline
                                  alex_ai @veye_xumm
                                  the version is same :
                                  rms@raspberrypi10:~/source/raspberrypi_v4l2/gx_i2c_tools $  ./gx_mipi_i2c.sh -r version
                                  Also updated and rebuilt source code - same result (only one difference I see : you are using gx_product_tool folder, for me it is gx_i2c_tools)
                                  We use F0.95 lenses on our cameras and remove the IR-cut filter to capture more starlight. The downside is that we can only achieve perfect focus for either visible or infrared light, though sharp focus is still possible for each individually. In our setup, we compromise by focusing somewhere in between.
                                  We see this exact behavior on our IMX462, IMX462 mono (VEYE), and IMX662 mono (another vendor ) sensors. However, on the color IMX662 sensor, I am unable to get a sharp focus at all. It feels as if the visible light and infrared light from the star interfere with each other simultaneously, making the image constantly blurry.
                                  I thought I could at least use this camera with an IR-cut filter, but for some reason, the stars became extremely dim. I am not sure if this is a software issue, or if the color Starvis 2 sensor simply handles light differently.
                                  See the sample photos below (please note - it is stack of 8 seconds) :
                                  imx662 without IR filter and no focus
                                  imx662 with IR filter and stars extremely dim
                                  and my imx662 mono sensor, without IR filter
                                    veye_xumm @alex_ai
                                    @alex_ai
                                    For your use case, I'd suggest giving it a try — reduce the denoise2d and denoise3d values, or even set them to 0. At the same time, you can also try lowering the sharpen value.
                                    • A Offline
                                      alex_ai @veye_xumm
                                      Hi @veye_xumm ,
                                      All my tests for parameters denoise2d, denoise3d and sharppen already have 0 value.
                                      Also played with all parameters in veye_viewer (very useful app) - no luck
                                        veye_xumm @alex_ai
                                        @alex_ai Sure, I'll keep an eye on this issue going forward. Thanks for your feedback.
