    VEYE-MIPI-IMX327S via V4L2
    20 Posts 2 Posters 5.8k Views 1 Watching
      veye_xumm @Dan_LionKing
      @dan_lionking
      The preview and snap cmd just works fine here.
      export DISPLAY=:0
      gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! fpsdisplaysink videosink=autovideosink sync=false text-overlay=false -v
      gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080" ! jpegenc ! filesink location=jpgname.jpg
      Please try again.
      By the way, 327S support FFC cable power mode.
      • D Offline
        Dan_LionKing @veye_xumm
        pi@raspberrypi:~ $ export DISPLAY=:0
        pi@raspberrypi:~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! fpsdisplaysink videosink=autovideosink sync=false text-overlay=false -v
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage: sync = false
        New clock: GstSystemClock
        /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
        /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
        /GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)YV12
        /GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
        /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
        ERROR: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage: Output window was closed
        Additional debug info:
        xvimagesink.c(555): gst_xv_image_sink_handle_xevents (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage
        Execution ended after 0:01:17.976117227
        Setting pipeline to READY ...
        Setting pipeline to NULL ...
        Freeing pipeline ...
        window "gst-launch-1.0" show, but no image from camera
          @dan_lionking
          It feels strange, can you try veye_raspicam mode to make sure the camera is working properly?
          Http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi.
          Remember to uninstall v4l2 driver, before you can use veye_raspicam mode.
          • D Offline
            @veye_xumm veye_raspicam mode work fine
              @dan_lionking
              I think I have an idea.
              This is my kernel version.
              ~ $ uname -a
              Linux raspberrypi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
              So the driver I use is in 5.10.17-v7l+ dir.
              I think maybe you have an older version kernel.
              The earliest small amount of VEYE-MIPI-IMX327S has a small different with VEYE-MIPI-327E, It has a valid reset pin. So the driver is required to control the state of the pin. And I also implemented it in the new version of the driver.
              I soon realized that this was not compatible with the older version of the driver, so we removed the diodes that were told you in post earlier to maintain compatibility.
              Here are my suggestions, any one of which can achieve the goal of solving the problem:
              1. If it is convenient for you, you can remove the diode I pointed out to you in the previous post.
              2. Update your kernel, to use the 5.10.17 Murray v7l+ version of the driver.
              3. Based on the source code of the veye327 driver, recompile the driver for your current version of kernel.
              • D Offline
                I am using the newest kernel version:
                pi@raspberrypi:~ $ uname -a
                Linux raspberrypi 5.10.17-v7l+ #1421 SMP Thu May 27 14:00:13 BST 2021 armv7l GNU/Linux
                Should I remove the diode?
                  @dan_lionking
                  It seems that I was wrong, but I suggest you try the above advice.
                  • D Offline
                    The diode was removed, the same thing.
                    Execution ended after 0:00:44.217242546
                    veye_raspicam mode work.
                      @dan_lionking
                      Hi,After discussing with my colleagues, I think I found the cause of the problem this time.
                      Please read hdver, only if hdver > = 5 can you use the v4l2 mode of raspberry pi.
                      http://wiki.veye.cc/index.php/VEYE-MIPI-IMX327S_version_log
                      Because the V4L2 model and 327s products are relatively new, we discovered and solved this bug after a short period of time.
                      As an apology, I can give you a new 327S at half price. You can contact customer service on AliExpress or amazon.
                      • D Offline
                        pi@raspberrypi:~/raspberrypi/i2c_cmd/bin $ ./veye_mipi_i2c.sh -r -f hdver
                        hardware version is 0x 4
                          @dan_lionking
                          I think that's the problem.
                          • D Offline
                            I recently ordered more modules VEYE-MIPI-IMX327S for AliExpress.
                            What date was this problem fixed?
                              @dan_lionking
                              I think it is 20210514.
                              • D Offline
                                @veye_xumm pi@raspberrypi:~/raspberrypi/i2c_cmd/bin $ ./veye_mipi_i2c.sh -r -f hdver
                                hardware version is 0x 5
                                work via V4L2
                                  @dan_lionking
                                  Right. That's the result.
