    2. VEYE MIPI camera
    Log in to post
    Load new posts
    • Recently Replied
    • Recently Created
    • Most Posts
    • Most Views
    • M
      This topic is deleted!
      Watching Ignoring Scheduled Pinned Locked Moved
      No one has replied
    • V
      Get IR cut triggered
      1k Views
      V
      Ok, will connect wire from IRLED to gpio.
    • W
      Need clarification on AGC, AESpeed parameters
      @watchever IMX385
    • V
      Limit max exposure
      1k Views
      V
      Thank you.
    • V
      Ir-cut switch order
      20
      6k Views
      @viktor You are welcome. Have a good day.
    • S
      RPI Camera IMX327 different brightness values between startups
      15
      4k Views
      @seka OK~
    • W
      Change IMX462 definition
      @watchever Do you use VEYE-MIPI-IMX462 ? I think it do not support other resolutions other than 1080p. http://wiki.veye.cc/index.php/VEYE-MIPI-IMX462_Data_Sheet This is a limitation of ISP.
    • W
      Problem with output array size of UYVY format
      7
      W
      Ok got it. I confirm output format is I420 and array order is correct. Thanks for your help
    • H
      imx462在米尔MYC-C8MMX开发板测试失败。求助
      7
      @hezudao 不客气~
    • A
      327S work on Raspberry pi CM4 module
      9
      @veye_xumm 由于时间太久了,客户没有进一步的反馈,我会把这个帖子标记为已解决.
    • W
      Get more than 1 sec of exposure on IMX462
      @watchever Hi, it is the ISP limit which VEYE-MIPI-IMX462 used.
    • S
      Subset array of IMX327 in Python
      @seka I'm not very familiar with python. But in my opinion, jpeg is compressed data, which can't be subset by simple sampling, is it?
    • X
      在树莓上执行命令报错,如图
      8
      @xsw 很好。 硬件是被动的,软件是主动的。 摄像头不能去操作主板的内存,是靠主板上的软件来操作摄像头,把数据放到内存。 树莓派是上我们提供的两种应用模式,都可以由软件获取到摄像头输出的数据。 请参考详细的文档和代码。
    • F
      CS-MIPI-IMX307在nvidia agx xavier开发板上适配失败
      F
      @veye_xumm 哦,好的,那可能是采购给我的型号弄错了,我用327的dtb再试一下,谢谢了
    • D
      VEYE-MIPI-IMX327S no image
      24
      9k Views
      @dan_lionking You are welcome.
    • W
      lowlight in veye_mipi_i2c.sh seems to do nothing
      8
      @watchever I think what you mentioned is mshutter. Yes, of course. mshutter : If you use manual mode, the exposure time will be independent of the ambient brightness.
    • W
      saturation, contrast, shutter speed, iso on VEYE-MIPI-462
      28
      13k Views
      @watchever For yuv , http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#yuvseq And I'm sorry , can not provide you such python code now.
    • W
      Python capture does not work with VEYE IMX462
      1k Views
      @watchever You are right.
    • W
      mshutter values in veye_mipi_i2c.sh
      @watchever Yes. VEYE series does not support exposure time longer than 1 second. CS series support this feature.
    • W
      Veye-raspipreview works at first run and not python demo and preview
      1k Views
      W
      Thanks xumm I have add rpi3-gpiovirtbuf initialize routine in the libdmipicam.so library, so don't need to run this binary alone and it works. Thanks
