    2. VEYE MIPI camera
    Log in to post
    Load new posts
    • Recently Replied
    • Recently Created
    • Most Posts
    • Most Views
    • W
      Difference between libveyecam.a
      Watching Ignoring Scheduled Pinned Locked Moved
      1k Views
      @watchever yes,you are right.
    • C
      亚博Xavier NX,按3.5升级,video都消失了
      17
      5k Views
      C
      @veye_xumm 明白了,谢谢!!
    • T
      Text overlay in veye_raspivid
      Watching Ignoring Scheduled Pinned Locked Moved raspberry overlay annotate veye-raspivid veye-mipi-327e
      7
      5k Views
      M
      @veye_xumm OK, thanks. Solved it by adding vc.ril.hvs component before h264 encoder and doing some fancy overlays by libcairo.
    • S
      Taking images with IMX462 in Python
      10
      @seka hi, VEYE-MIPI-IMX462 do not support YUV 10BIT/12BIT.
    • V
      veye327 failed on nano 2gb
      V
      @veye_xumm Ok, thanks.
    • D
      VEYE-MIPI-IMX327S via V4L2
      20
      6k Views
      @dan_lionking Right. That's the result.
    • S
      Error with camera_i2c_config and IMX462
      1k Views
      @seka Thank you for sharing.
    • S
      no read-out from i2c whitebalance
      1k Views
      S
      @veye_xumm Thank you Xu, downloaded the new file and now it is working like a treat!
    • S
      VEYE MIPI 327E,按3.5 升级方法,更新失败
      已与瑞泰沟通驱动移植事宜。
    • S
      Automatic gain function i2c
      1k Views
      S
      @veye_xumm Thank you! That made it clear to me
    • E
      使用I2C.sh配置VEYE-MIPI-327树莓派4B就卡死
      9
      @eledog 我们装了一个你用的lite版本,运行是没有问题的。 [image: 1623146723636-9ecdb20e-ebc2-49f8-8719-e16be7cff655-image.png] 你用的硬件是4GB版本,我们的是2GB版本。 我这没法重现的情况下,你可以尝试103-123行进行逐行注释来找一下原因。 [image: 1623146803776-bb570ba3-c8aa-4d0a-828b-a582d8b0222e-image.png]
      VEYE-MIPI-327E 颜色偏红是怎么回事呢?
      1k Views
      L
      @veye_xumm 哦,这个平时没太注意,我去了解一下镜头是否带有滤镜
      如何修改D_init_camera_ex 获取出的视频大小以及fps
      L
      @veye_xumm 好的我试试
    • V
      OpenCV. Crop and change resolution to increase FPS
      9
      4k Views
      @mk No such plan, this cannot be supported. Sorry.
      按文档安装V4L2驱动,出问题,看是看不到video0设备
      18
      6k Views
      L
      @veye_xumm 好的
      This topic is deleted!
      No one has replied
      插上树霉派,怎么弄都找不到video0设备
      @luchec 不客气
      增加4L2
      1k Views
      @luchec 你好,树莓派的图像部分是一个封闭系统,默认不能支持非官方的摄像头。所以要增加我们摄像头的驱动。 http://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi/zh
    • T
      查看默认i2c参数表
      1k Views
      @toosim 你好,我们暂时未提供默认参数表,您可以通过读取命令读取默认值。 另外,我们的文档上面,一般每个功能都写了默认值是多少的。
    • H
      VEYE-MIPI-327更新image和dtb后,应用测试没反应,该怎么解决?
      7
      H
      @veye_xumm 好了,应该没问题了,是因为我没有屏的缘故,谢谢
