• Problem with GXC-MIPI-IMX662
    18
    1k Views
    @alex_ai You are welcome.
  • Problems to make work camera IMX462M
    @habreu If you are using the RAW-MIPI-IMX462M camera module, the corresponding script is mv_mipi_i2c_new.sh. Please note that many parameters can only be modified when frame capture is stopped. For details, please refer to the following link: https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide
  • MV-MIPI-IMX287M模块能否输出subLVDS信号
    @lpcq2000 这个不支持输出lvds信号。J1作为我们模组内部的信号,不对外公布其信号定义。
  • GX-MIPI-IMX662 can't save fps parameter
    25
    6k Views
    @alex_ai Sure, I'll keep an eye on this issue going forward. Thanks for your feedback.
  • Jetson Orin NX IMX264M
    @123456123 said: X Developer Kit 上用 VEYE MV-MIPI-IMX264M。系统是 R35.5,内核 5.10.192-tegra。把 FDT 切到 VEYE 的 dtb,并替换成 VEYE patched Image 后,重启就会黑屏,但 SSH 还能连上。想请教一下怎么解决。 Jetpack5.1.3,L4T版本r35.5 说实话这个版本的jetpack有点老了。但是我们应该是做过验证的。 请将你的extlinux.conf文件的内容贴出来。 另外: https://wiki.veye.cc/index.php?title=How_to_upgrade_the_Jetson_system_to_support_VEYE_cameras/zh#Image和DTB更新成功了吗? 第8节的内容,执行一下,把结果发出来,我看看。
  • GX-MIPI-IMX662 4-lines mipi support
    @oleg Not supported. The bandwidth of 2 lanes is sufficient.
  • different modules simultaneously on jetson nano mipi interface
    15
    7k Views
    @joe Of course.
  • 0 Votes
    @jossen 不客气。
  • 请教 关于bit数的问题
    8
    4k Views
    @nian 不好意思,我们暂时没有计划做raw14bit输出的camera模组。
  • MV-MIPI-SC130M抓图报错
    1k Views
    @乔康 @乔康 said in MV-MIPI-SC130M抓图报错: 驱动正常加载。虽然设备树是4lane的。 问题就在这里,MV-MIPI-SC130M不支持4lane模式配置。 你需要更换设备树为2lane模式。
  • imx462与rk3588无法出图问题
    @乔康 这个问题我们没有遇到。 你可以试试直接用v4l2-ctl抓图,看看效果如何? https://wiki.veye.cc/index.php/VEYE_CS_Camera_on_Firfly_Boards/zh#.E6.8A.93.E5.8F.96.E5.9B.BE.E7.89.87
  • raw-mipi-sc132,SDA模式
    8
    @ouyangxin 你好,你理解的没错,但是我们现在已经取消了对sda模式的支持,所以这上面的讨论已经没有意义了。
  • Jetson Nano Orin IMX462
    7
    @d_101 Sorry for the late reply. Based on the current situation, I can only suspect a hardware issue that is causing the I2C path to be unavailable. This could be a problem with your mainboard or with the camera itself. Please return the camera to us, and we will perform testing and inspection.
  • MV-MIPI-IMX264M Mono12
    1k Views
    @ffgemanof The veye_viewer client currently does not support the mono10 and mono12 formats. If you need to use these formats, please configure the data format using mv_mipi_i2c_new.sh, and then acquire the data using v4l2-ctl or the V4L2 API.
  • 0 Votes
    6k Views
    J
    Hi @veye_xumm, thank you again for all your help. I found that the VEYE camera you made available with I2C address 0x22 does work on the J401B. And now, after a long series of follow-ups with Seeed Tech Support, I found that i2cdump generates I2C transfer timeouts at address 0x3b (but only 0x3b!). Then Seeed noted that applying the VEYE "compatibility fix" updating the USB Hub firmware to 08C3 removed the timeouts. So I tried that with the VEYE camera and it works! (This with Jetpack 6.1). A weird puzzle remains, I was sure the J401B had USB Hub Firmware version 08C3 as supplied, although with one of the "devices" giving different details to 08C3 on the J401. Hence I did not expect to need the "compatibility fix", and had some concerns that reapplying it could cause a problem. But reapplying the update just now the firmware version was initially 08B3!? It has updated to 08C3, and has fixed camera access to 0x3b. This has been time consuming, but I might now test JetPack 6.2
  • veye-mipi-IMX462 on rpi5 get video stream but cant controll via v4l2 or i2c
    10
    4k Views
    B
    @veye_xumm Sorry for the late reply. Thank you for the new code! It seems to work partially in the rpi5 standard OS. I was able to compile the read and write files, and some commands work while others don't. The new mgain is stuck at zero, so if i use new exp mode i can set the shutter speed with new mshutter, but not the new mgain, despite changing it returns zero when i probe with the -r parameter. so using the new exp mode i only get a black image. the old mshutter works and i was able go get up to 1 second exposure per frame in streaming mode but the capture mode and capture command don't seem to work. Also i would like to have it work in the rpi archlinux OS that i use for astronomy. The veyecam2m driver works and i get video in the archlinux OS, but i wasn't able to compile the i2c read and write in that system.
  • Saving VeyeMIPI parameters
    @nimadibaj You have implemented the function of writing 0xff to 0x000b. Similarly, proceed to write the subsequent registers as well. The method for writing the subsequent registers is the same as that for writing the 0x0b register, but they must be written in sequence. Addr--->data 0x10 0xDE 0x11 0xC2 0x12 0x00 0x13 0x00
  • Veye MIPI imx462 Defaults
    8
    4k Views
    N
    @veye_xumm Hello my friend. We are sending I2C commands via a FPGA. 1_ Writing 0xff to 0x000b solved our problem. Thank you. Please give us a command to save this change. 2_ We are trying to change video frame rate (now is 30fps and we need 25fps). by these commands we cannot do this : 0x10 0xDE 0x11 0xC2 0x12 0x00 0x13 0x00 (sending Two byte, then sending next two byte and ... ). Please guide me. Thanks a lot.
  • Camera Paramter saving
    @deepcamera Only ISP-related parameters can be persistently saved after power-off through the paramsave command. Therefore, I recommend that you reconfigure your desired parameters in the startup script during program design. As for which commands can be saved, you can refer to the veye_mipi_i2c.sh source code. If the corresponding read/write functions contain operations like './i2c_write $I2C_DEV $I2C_ADDR 0x10 0xDA', it indicates that the function's register belongs to the ISP category and can be saved using paramsave.
  • VEYE-MIPI-327E lens YT1.8-2.8I poor picture quality in the dark
    @siderat I think this one will work.
