• 0 Votes
    若
    @veye_xumm 好的,感谢,找到了,得用新的链接,我用的是之前旧的链接
  • VEYE_MIPI_IMX462编译raspberrypi_v4l2报错
    @xmy 编译完之后,按照文档的part3部分,安装驱动就可以了。 https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh
  • VEYE-MIPI-327S是否可用raspistill指令输出包含bayer数据的.jpg图
    16
    6k Views
    X
    @veye_xumm OK,明白,多谢!
  • RAW_MIPI_SC535M设置ROI
    毛
    @veye_xumm 感谢
  • RAW-MIPI-SC535M格式取流设置问题
    @毛宪历 这个板子上,请使用如下命令进行测试先: python3 ./v4l2dev_2_opencv_show_grey.py --width 2432 --height 2048 --fps 50 --i2c 7
  • This topic is deleted!
  • 相机提供C++的SDK吗?支持SDK的开发方式吗?
    1k Views
    @毛宪历 不好意思,现在我们还没有提供成型的SDK。 提供的资料是以标准v4l2接口实现的。 你可以参考下面这个链接的7.4.4 yavta应用范例。 https://wiki.veye.cc/index.php/MV_Camera_on_Firfly_Boards/zh#yavta.E5.BA.94.E7.94.A8.E8.8C.83.E4.BE.8B
  • jetson xavier nx开发板相机驱动更新导致的系统问题
    W
    @veye_xumm 好的,非常感谢
  • VEYE-MIPI-IMX462 WDR MODE GHOST PROBLEM
    @skysplitter It is recommended that you turn off the 3D denoise and wdr features if you have a relatively fast moving vehicle in your usage scenario. This is because these two features essentially use two frames of data to calculate. 2d denoise can be turned on.
  • NVidia Jetson Jetpack 6 support?
    55
    40k Views
    @vitob said in NVidia Jetson Jetpack 6 support?: In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks. These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other. Their code reference: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3 Compile step by step reference:: https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
  • mv-mipi-sc130m在Xavier nx上无法
    1k Views
    O
    Did u solve it ??? Iam using jetson nano B01 Devkit I have exact problem like u : [image: 1725393713979-1b047cd6-2fcf-43d5-a62e-ded2c5ab38de-image.png]
  • 相机运行一段时间后出现阻塞
    15
    7k Views
    @lin 相机触发模式出图和流模式出图,对你的程序接收图像而言,没有区别啊!
  • MIPI-VEYE462 menu on screen display
    1k Views
    @oleg This link provides a reference for workarounds to this problem. Camera menu appears on VEYE-MIPI-IMX327S However, I'm curious why this issue occurs so frequently on your end. Could you please measure the SCL level using an oscilloscope? When the VEYE module is not configured, SCL should always remain high. If there are frequent and continuous level changes, it indicates that the system is operating on the I2C bus. [image: 1722838648747-430b65cc-ea10-47f9-ae2a-42c02f3119eb-bddd9a7161c7e66c0648f1da3766162.png]
  • Can't select 25Hz framerate on MIPI IMX462
    @carrot said in Can't select 25Hz framerate on MIPI IMX462: Please try this: sudo ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL -b 9 gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! "video/x-raw(memory:NVMM),format=(string)UYVY,width=(int)1920,height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! fpsdisplaysink video-sink=fakesink -v
  • 相机采集图像阻塞
    37
    25k Views
    T
    @veye_xumm 请问FPGA和RK3588直连,没有I2C,怎么在设备树里添加相机?相机驱动又该怎样处理?
  • IMX462 拍摄的小短片
    No one has replied
  • 关于 CM4-NANO-B 同时使用CSI(IMX462)和DSI (微雪屏幕)
    No one has replied
  • 3568上加载AR0234M
    9
    @lin 应该还是设备树配置的问题。
  • 移植MV-IMX265驱动程序到迅为RK3568抓图卡死
    39
    29k Views
    @w88121446 我们用的firefly的板子,gstreamer是支持gray8数据格式的。
  • Ar0234M isp畸变校正
    1k Views
    @lin 你好,现在我们并没有使用rk3588内部的isp的经验。不好意思。
