• IMX327相机video0获取流报错
    F
    @veye_xumm 感谢感谢
  • VEYE-MIPI-327E 在樹梅派上如何設定RTSP?
    F
    针对RTSP这个,一般只需要一个rtspd服务器就行,可以移植live555,或者直接用gstreamer的rtsp服务器插件,甚至可以直接用ffmpeg进行rtsp推流,接收的时候,用vlc即可。
  • This topic is deleted!
    1k Views
  • 0 Votes
    @liubo1999 读取0x0424寄存器地址的数据全是0x00,请问是不是我设置的报文发送的不正确?举个例子,数据类型是bool的数据,我可以发一个字节作为设置值吗?还是说必须一次设置4个字节? 所有数据类型,都是必须使用4个字节的。 还有一个问题,就是说,如果成功设置成为“MCU bypass mode”模式后,是不是仍然在当前的I2C总线上与传感器通讯?MCU只是作为透传功能是吗? 设置之后,电路上外部与sensor的i2c通信不经过mcu,是直接联系的。i2c地址也是各自sensor的地址了。
  • rtsp服务
    N
    @国电富通 可以找一下网上开源的rtsp, 在板子实现一个rtsp server 然后电脑用vlc访问
  • IMX462 with Raspberry Pi Zero 2
    @veye_xumm The feedback from this link below is the same as your problem, and although it is in Chinese, the images in it are informative. https://forum.veye.cc/topic/187/veye-mipi-imx385在新版raspberry-pi-zero-2-w上无法使用 I'll list the points to use: Use a separate 5V supply. On the raspberry pi zero 2w, the power on enable pin for camera, needs to be executed separately: raspi-gpio set 40 dh Once this is done, the camera can be detected on the i2c-10 bus. i2cdetect -y 10 The 0x3b device can be detected and the script can read and write camera parameters now. After completing the above steps, you can use the veye_raspicam series software normally.
  • RAW-MIPI-AR0234M
    @jose5000 Please run the commands from part3.7 of this link and post the results here. https://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Are_Image_and_DTB_upgrade_successful_.3F
  • IMX327S IR-Cut Heat
    N
    @veye_xumm Thank you. And agreed, it's heat transfer. Everything is stable and works great. Good to know it's normal.
  • CS-LAMP-IR Frame Synchronization
    @nimble99 Hi, this board won't work for you. It's a IR lamp running a full duty cycle.
  • 如何设置ar0234接收单通道的图像。而不是rgb的。
    1k Views
    @lizi 你好,我们这个相机本身是黑白的,只有一个通道。 驱动输出的数据也是单通道的。 你的意思是进入opencv现在是三通道模式的? 不好意思,这个我们对opencv的确不太熟,这方面需要再研究。
  • imx462寄存器值
    26
    13k Views
    @canglin 默认是discontinues模式。
  • New Raspberry pi 5 support
    25
    14k Views
    V
    @vaa said in New Raspberry pi 5 support: @veye_xumm In case I try to set pixel_format to any other value is cause VIDIOC_STREAMON fail. I suppose this is a bug in the driver. Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not. Will you going to fix the issue?
  • 3588修改行对齐
    12
    5k Views
    L
    @veye_xumm 好的,谢谢
  • 0 Votes
    @liliant 一般来说,能出图,i2c是通的;那么摄像头应该没有坏,控制参数也应该生效才对。
  • IMX327S with reComputer Xavier/Nano
    12
    4k Views
    @newleaf You are welcome.
  • 调用摄像头方法
    20
    13k Views
    @hxm [image: 1704416842228-fcf1a632-3381-4084-817b-f27489ad76ae-image.png]
  • veye-mipi-imx287m识别不到
    26
    15k Views
    S
    @veye_xumm 我换块板子试试吧
  • mv_mipi_i2c.sh
    @hxm https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/mv_tools_jetson
  • VEYE-imx462 and Orin Nano developer kit problem
    17
    6k Views
    @joe yes
