• IMX462 ISP设置失败
    1k Views
    @peter 你好,中括号[]不需要输入。比如-p1 NTSC,这样即可。
  • This topic is deleted!
    No one has replied
  • 0 Votes
    S
    @veye_xumm said in Driver Problem for Jetson Nano 4GB Developer Kit and VEYE-MIPI-327-fpdlink Camera Module: @samet_moveon [image: 1702432469399-3a1f99aa-daca-4ba5-991b-0cfd6294253c-image.png] According to your previous hints, it seems that your FPD-Link channel has been successfully established, and Jetson can access the camera through I2C. However, there are several errors in your driver that need to be addressed. We use the camera I mentioned above in our products and I need to solve this problem so that we can proceed to the production phase, can you please help me how to solve this problem? Also my version is Jetpack4.5, L4T r32.5 and I have to use this version.
  • IMX462与3588匹配问题
    24
    12k Views
    乔
    @veye_xumm [image: 1702446803775-1fc9cba1-4600-4a24-abb6-e2b025bbd568.jpeg] 格式是nv12了。但分辨率对不上。(将lvds_sditf disabled 以后)
  • SC130M搭配RK3588不出图
    26
    7
    14k Views
    M
    @veye_xumm 使用vooya打开了图像 [image: 1702361336825-364335c7-cb24-4c35-be07-4752de0a4ad6-image.png]
  • mv-mipi-sc130m搭配RK3588出图问题
    8
    4k Views
    @m4416202 你可以参考这个帖子,跟你的问题类似。https://forum.veye.cc/topic/501/sc130m搭配rk3588不出图/16
  • 关于在RK3588平台上抓图的问题
    @geniusdo 一般来说,每一个mipi口都会有一个单独的i2c总线与之对应。
  • imx462 on RockChip 3399 (OP1) Asus Tinker Board 2
    @vaa @vaa said in imx462 on RockChip 3399 (OP1) Asus Tinker Board 2: Do you have imx462 camera with USB3.0 interface (UVC driver) then? No
  • Long distance MIPI
    @hchorsi The following link has a 50cm FFC cable. However, please note that when using such an extra-long FFC cable, you need to provide separate power to the camera. https://de.aliexpress.com/item/4001257031331.html
  • mv-mipi-sc130m在Xavier nx上无法识别到设备
    32
    24k Views
    S
    @veye_xumm 好的谢谢您
  • MV-MIPI_IMX264M相机画面卡顿
    1k Views
    @zzz 平台接入问题,已联系线下解决。
  • Veye IMX 462 RK3566 ORANGE PI 3B
    7
    @esjeeybi The driver code for RK358x and RK3566 is almost identical. You can check the "veyecam2m.c" file in both directories to confirm this. What I mean is that you can leverage the driver code provided for RK358x kernel version 5.10 and port it to Orange Pi.
  • imx307工作着突然不出图了,mipi数据无信号
    8
    @vladimi-zheng 他这个跟你的问题应该不是一回事。你这个我首先怀疑fpc叠放,引起了信号串扰。
  • Orin 35.3.1平台 6路IMX307相机异常挂掉问题
    1k Views
    @jdx-jdx [image: 1698395182377-3b2b4efe-374b-4427-a793-4d689364d5f5-image.png] 这种排线的堆叠摆放会产生很强的信号串扰。 你这种情况需要改一下排线摆放,或者更换为带有屏蔽层的FFC cable。
  • veye-mipi 327的wdr和sharppen无法同时起效
    1k Views
    @harryxiong 你好,已经增加了wdrsharppen的设置功能。请参考: https://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#wdrsharppen
  • imx462 lowlight 0x20 parameter
    1k Views
    V
    @veye_xumm Thank you very much!
  • MIPI接口收到电磁辐射干扰
    1k Views
    @stevenyang 如果是电磁辐射,必须改为屏蔽线。 你也可以尝试一下下图这种铝膜覆盖和导电布覆盖的ffc线。 [image: 1696668562643-f1d27e41-18cf-43b4-a98f-ba6e88d6f02e-f8bd68b76bc00b00f7e9a62f402b0ab.png]
  • raw-mipi-sc132在Nano B01上使用遇到的问题
    @cheesefish 不客气。
  • VEYE-MIPI 327E on NX215 carrierboard
    @lucas https://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#hdver ./veye_mipi_i2c.sh -r -f hdver -b [i2cbus] You can use this command to identify the hdver of your camera.
