• Purple hued images with IMX327.
    @newleaf Looking at the image you sent, I do think it's an IR cut issue. Could you tell me which aespeed-related command you used to reproduce this phenomenon?
  • 设置曝光值有限制
    16
    6k Views
    @lin 不客气。
  • 多通道相机设备树设置
    L
    @veye_xumm 解决了,dphy4不支持4lane
  • IMX327在樹梅派Zero W上驅動問題
    7
    @leo12757 你好,抱歉这两天比较忙,我给一个大体的思路您可以试一下。 install_driver.sh在安装驱动的时候,做了如下两处更改,您可以手动去掉,然后重启系统后再测试一下。 Add gpu=256M to ${CONFIG_FILE},CONFIG_FILE="/boot/firmware/config.txt" or CONFIG_FILE="/boot/config.txt" echo "Add cma=128M to /boot/cmdline.txt "
  • 0 Votes
    若
    @veye_xumm 可以了,非常感谢
  • veye-mipi-imx462在树莓派5上无法用i2c设置参数
    @sqf121 不客气。
  • 脚本修改lane值
    11
    4k Views
    L
    @veye_xumm 好的,已解决
  • 相机设备树修改
    10
    L
    @veye_xumm 好的,已解决
  • RAW-MIPI-IMX462M 長時間曝光設定
    @atboy 通过邮件联系吧。sales@csoneplus.com
  • 相机驱动
    38
    27k Views
    @023 就是最常用的1.25间距白端子。
  • How to get actual gain and shutter?
    1k Views
    @egor Sorry, this feature is not supported right now.
  • 0 Votes
    6k Views
    @张志伟 按照我我们wiki上步骤去调用yavta存图一定是可以的。你把你用的命令发出来我看看。
  • 获取相机图像帧被阻塞
    1k Views
    L
    @veye_xumm 解决了,重启后,可以了
  • Recommendation to reduce startup latency for IMX327S
    1k Views
    @newleaf said in Recommendation to reduce startup latency for IMX327S: For our system, we utilize 940nm IR lighting at night that is triggered by motion. I noticed that there is a 1-3 second period for the camera to adjust each time if we start streaming when the lighting is activated. The first few images are washed out until AE kicks in. What's the recommended approach to eliminate this latency and the initial washout? Should we explore manual exposure and gain? Thx! You can try configuring aespeed first, and then try manual mode if that doesn't meet your needs. https://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#aespeed
  • imx462 driver update for raspberrypi 6.1.21-v8+
    1k Views
    @zoldaten Approve
  • 编译veye_mvcam.ko报错
    @lin said in 编译veye_mvcam.ko报错: RKMODULE_CSI_INPUT forlinx的kernel源码不支持RKMODULE_GET_CSI_DSI_INFO这个宏定义,可以注掉代码。
  • 相机硬触发,采集图像
    29
    21k Views
    @lin 是的。 不过你要是用视频流模式当然可以咯。
  • IMX462 and Jetson Nano problem
    1k Views
    @joe The software part of the work seems fine. Next, we need to check if the hardware connections are correct, paying particular attention to the orientation of the FFC cable.
  • IMX462 15pin 1mm pitch to 18pin to 0.5mm pitch connection
    @lukapercic The number of pins and the spacing of the connectors are different, so I believe they cannot be directly connected together.
  • This topic is deleted!
    1k Views
