    New Raspberry pi 5 support
    25 Posts 4 Posters 13.9k Views 1 Watching
    • N Offline
      natzguk @veye_xumm
      @veye_xumm Hi do you have any update on the Raspberry Pi 5 support? Thanks
        veye_xumm @natzguk
        @natzguk We've already obtained the Raspberry Pi 5, and we estimate that the driver will be released next week.
          veye_xumm @natzguk
          @natzguk
          Over the past few days, we've been attempting to port our driver to the Raspberry Pi 5.
          Unfortunately, we've encountered some issues.
          It seems that on the RPi 5, libcamera is a necessary option, and the Raspberry Pi organization has removed the path for us to directly obtain camera images from the MIPI RX port.
          This is not a final conclusion, and we are still working hard to find a solution.
          • N Offline
            natzguk @veye_xumm
            Thanks for the update! Hope you can find a solution
              veye_xumm @natzguk
              @natzguk
              Plese check this release :
              https://github.com/veyeimaging/raspberrypi_v4l2/releases/tag/v1.17
              and this document:
              https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi/
              • V Offline
                Vaa @veye_xumm
                @veye_xumm Nice to see you have managed!
                The second link is not works. There is the last slash must be removed in the URL.
                I'm going to test it as soon as possible.
                  veye_xumm @Vaa
                  @vaa https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi
                  • V Offline
                    Vaa @veye_xumm
                    I have successfully installed RPI5 driver veyecam2m.
                    I somehow managed to get uyuv frame from veye imx462 camera
                    using v4l2-ctl utility. (VLC is not working as mentioned).
                    But in my c++ project I use Linux v4l2 recommended procedure for capturing frames, and it doesn't work (It worked normally for RPI4).
                    VIDIOC_DQBUF fail, VIDIOC_STREAMON fail.
                    What is your recommendation for frame capturing algorythm?
                      veye_xumm @Vaa
                      @vaa Before running your program, have you executed the ./media_setting_rpi5.sh veyecam2m script?
                      • V Offline
                        Vaa @veye_xumm
                        @veye_xumm Yes, I have. I did everything recommended.
                        Btw, I found VLC can preview ONLY if UYVY colorspace is set. It preview with wrong green-violet picture, but at least it does.
                          veye_xumm @Vaa
                          @vaa Yes, indeed. That's what confuse me.
                          V A 2 Replies Last reply Reply Quote 0
                          • V Offline
                            Vaa @veye_xumm
                            @veye_xumm Are you going to improve your driver's compatibility?
                            • A Offline
                              alex_ai @veye_xumm
                              • A Offline
                                alex_ai @alex_ai
                                • A Offline
                                  alex_ai @alex_ai
                                  Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m
                                  @veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
                                    veye_xumm @Vaa
                                    @vaa
                                      veye_xumm @alex_ai
                                      @alex_ai
                                      • V Offline
                                        Vaa @veye_xumm
                                          veye_xumm @Vaa
                                          @vaa
                                          • V Offline
                                            Vaa @veye_xumm
                                            Here is a receipt how can I achived this:
                                            1. ./media_setting_rpi5.sh veyecam2m
                                            2. ./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
                                            3. ./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
                                            4. In my app open device /dev/video0 with following parameters:
                                              width 1920;
                                              height 1080;
                                              field_format V4L2_FIELD_NONE
                                            Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.
                                            V 1 Reply Last reply Reply Quote 1
