    New Raspberry pi 5 support
    25 Posts 4 Posters 14.5k Views 1 Watching
    • V Offline
      Vaa @veye_xumm
      @veye_xumm Yes, I have. I did everything recommended.
      Btw, I found VLC can preview ONLY if UYVY colorspace is set. It preview with wrong green-violet picture, but at least it does.
        veye_xumm @Vaa
        @vaa Yes, indeed. That's what confuse me.
        V A 2 Replies Last reply Reply Quote 0
        • V Offline
          Vaa @veye_xumm
          @veye_xumm Are you going to improve your driver's compatibility?
          • A Offline
            alex_ai @veye_xumm
            • A Offline
              alex_ai @alex_ai
              • A Offline
                alex_ai @alex_ai
                Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m
                @veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
                  veye_xumm @Vaa
                  @vaa
                    veye_xumm @alex_ai
                    @alex_ai
                    • V Offline
                      Vaa @veye_xumm
                        veye_xumm @Vaa
                        @vaa
                        • V Offline
                          Vaa @veye_xumm
                          Here is a receipt how can I achived this:
                          1. ./media_setting_rpi5.sh veyecam2m
                          2. ./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
                          3. ./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
                          4. In my app open device /dev/video0 with following parameters:
                            width 1920;
                            height 1080;
                            field_format V4L2_FIELD_NONE
                          Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.
                          V 1 Reply Last reply Reply Quote 1
                          • A Offline
                            alex_ai @veye_xumm
                            @veye_xumm said in New Raspberry pi 5 support:
                            @alex_ai
                            I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
                            @veye_xumm thank you for help and support!
                              veye_xumm @alex_ai
                              @alex_ai You are welcome.
                              • V Offline
                                Vaa @Vaa
                                Will you going to fix the issue?
