    树莓派64位连接CS-MIPI-IMX307问题
    26 Posts 2 Posters 11.5k Views 1 Watching
    • F Offline
      fancong
      我这边有一个树莓派CM4,烧录最新的64位bullseye,连接相机的时候,没有发现/dev/video0节点,我执行了如下操作:
      1. 配置rasp-config为Legacy Camera Enable;
      2. 执行./enable_i2c_vc.sh并重启;
      3. 执行./camera_i2c_config报错:
        setting GPIO for board revsion: c03140
        CM4 - assume CAM1 on 44&45
        ./camera_i2c_config: 255: ./rpi3-gpiovirtbuf: not found
        然后执行目录下面的./rpi3-gpiovirtbuf也是提示找不到该文件,怀疑该程序是32位的,翻了一下论坛,都只是有编译i2c_read和i2c_write,没有这个程序的64位编译,
        请问楼主大神,这个该怎么解决啊?
        veye_xumm @fancong
        @fancong
        https://wiki.veye.cc/index.php/Raspberry_Pi_Application_Note_Index/zh
        估计你看错了文档。64位系统不能使用legacy模式,需要使用v4l2模式。
        v4l2模式才生成/dev/video0节点。
        • F Offline
          fancong @veye_xumm
          大神您好,按照这个文档,我加载驱动后重启,dmesg打印如下错误:
          fancong@raspberrypi:~$ dmesg | grep imx
          [ 0.067734] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/csimx307@3b
          [ 7.304776] csimx307: loading out-of-tree module taints kernel.
          [ 7.307571] csimx307 10-003b: supply VANA not found, using dummy regulator
          [ 7.307929] csimx307 10-003b: supply VDIG not found, using dummy regulator
          [ 7.308083] csimx307 10-003b: supply VDDL not found, using dummy regulator
          [ 7.316034] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
          [ 7.317349] csimx307: probe of 10-003b failed with error -121
          我想知道,这个cs-mipi-imx307是否需要接红黑电源线,我看接线文档里面说不需要,imx307小板上面上电之后,会有啥表现吗?例如有指示灯之类的
            veye_xumm @fancong
            @fancong
            没有指示灯。
            不需要接红黑电源线。
            你看一下fpc线的方向,有没有接反了?
            或者拍一下fpc接口的照片我看看。
            • F Offline
              fancong @veye_xumm
              @veye_xumm ![替代文字](screenshot-20240319-105841.png screenshot-20240319-105828.png 图片地址)
                veye_xumm @fancong
                @fancong 看起来树莓派那头插反了
                • F Offline
                  fancong @veye_xumm
                  @veye_xumm 线没接错哦,我换了一个imx290,可以识别到:
                  [ 0.068153] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/imx290@1a
                  [ 7.133686] csimx307: loading out-of-tree module taints kernel.
                  [ 7.138194] csimx307 10-003b: supply VANA not found, using dummy regulator
                  [ 7.150271] csimx307 10-003b: supply VDIG not found, using dummy regulator
                  [ 7.150441] csimx307 10-003b: supply VDDL not found, using dummy regulator
                  [ 7.158951] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
                  [ 7.159789] csimx307: probe of 10-003b failed with error -121
                  [ 7.209372] imx290 10-001a: 16-bit write to 0x301c failed: -121
                  [ 7.211146] imx290 10-001a: 24-bit write to 0x3020 failed: -121
                  [ 7.212098] imx290 10-001a: 24-bit write to 0x3018 failed: -121
                  [ 7.213639] imx290 10-001a: 24-bit write to 0x3020 failed: -121
                  [ 7.213706] imx290 10-001a: Consider updating driver imx290 to match on endpoints
                  • F Offline
                    fancong @veye_xumm
                    @veye_xumm 有没有可能是相机固件需要重新刷?
                      veye_xumm @fancong
                      @fancong 不需要重刷固件。如果排线方向没问题,那么有可能需要红黑线供电。
                      我现在不清楚你的底板的供电能力如何,你可以短时间用红黑线给307供电试一下。不要长期这么用。
                      回头测试完成告诉我结果。
                      • F Offline
                        fancong @veye_xumm
                        @veye_xumm 收到,我试试,谢谢大佬
                        • F Offline
                          fancong @veye_xumm
                          @veye_xumm 我试了一下,单独加上供电,也不行,我还原成老版本的32位系统看看吧
                          • F Offline
                            fancong @veye_xumm
                            @veye_xumm 还原成32位版本,也不能识别,这个是咋回事儿啊?老板大神,求指教
                            • F Offline
                              fancong @veye_xumm
                              @veye_xumm 相机接上红黑线之后,也在发热
                                veye_xumm @fancong
                                @fancong
                                这个跟64位系统和32位系统没有关系,都能支持。
                                看你的提示,
                                显示i2c-10上面找不到摄像头。
                                你这个板子总共引出了几个camera接口? 确定测试307的时候是插到i2c-10的吗?
                                • F Offline
                                  fancong @veye_xumm
                                  @veye_xumm 一共只有一个CSI口和一个DSI口
                                  • F Offline
                                    fancong @veye_xumm
                                    @veye_xumm 应该是插在CSI0了,如何选择哪个CSI呢?
                                      veye_xumm @fancong
                                      @fancong said in 树莓派64位连接CS-MIPI-IMX307问题:
                                      你调试290也是放在同一个CSI接口的吗? 是不是dtb有冲突啊?
                                      你把/boot/config.txt里面的内容贴出来我看看。你把/boot/config.txt中其他相机相关的东西注掉试试。
                                      • F Offline
                                        fancong @veye_xumm
                                        @veye_xumm 我后面重新烧录了32位的了,没有290的驱动了,只是我们自己的cs-mipi-imx307的,新的打印如下:
                                        $ dmesg | grep imx
                                        [ 5.458365] csimx307: loading out-of-tree module taints kernel.
                                        [ 5.470420] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
                                        [ 5.475082] csimx307: probe of 10-003b failed with error -121
                                        $ dmesg | grep csi
                                          veye_xumm @fancong
                                          @fancong 你的底板是自己做的对吧? 引出的是CM4的CAM1还是CAM0?对应的I2C是什么?
                                          • F Offline
                                            fancong @veye_xumm
                                            @veye_xumm 不是自己做的,是买的第三方的
