    IMX462M pixelformat on RPi5
    24 Posts 2 Posters 20.3k Views 1 Watching
      veye_xumm @alex_ai
      @alex_ai
      To facilitate the application of the mv series cameras, we have released a beta version of the libcamera support package.
      It doesn't do isp tunning, so you can try it out. Please contact me if you have any questions.
      https://github.com/veyeimaging/libcamera
      https://github.com/veyeimaging/raspberrypi_v4l2
      • A Offline
        alex_ai @veye_xumm
        Hi, thank you for update.
        I'm stuck with compiling libcamera now, with same error as here : https://github.com/raspberrypi/libcamera/issues/151
        Did not find solution yet, probably need play with source code, will let you know if any updates.
          veye_xumm @alex_ai
          @alex_ai
          You can use the latest libpisp and try again.
          • A Offline
            alex_ai @veye_xumm
            Hi, it helped but I had to use 1.0.6 tag of libpisp, with the latest version I had compile errors.
            Now for command : rpicam-hello -v
            I have this error:
            I used set media script before:
            Maybe forgot something else.
              veye_xumm @alex_ai
              @alex_ai ./media_setting_rpi5**.sh is not necessary.
              • A Offline
                alex_ai @veye_xumm
                Hi, I noticed that version of libcamera different on my screenshot (it 0.2.0 but I installed 0.3.0)
                I uninstalled rpicam-apps and rebuild it from source code again and it uses my version of libcamera now.
                if execute rpicam-still -v I have next error:
                In commit I see added json file only to vc4 folder (for RPi4) , can we add it to pisp folder (for RPi5) it should have name : "mvcam_mono.json"? it has different format and can't use same file from vc4.
                Also I managed start video by this command:
                rpicam-still --tuning-file /source/libcamera/src/ipa/rpi/pisp/data/uncalibrated.json -t 0
                and it works!
                But better run it without additional parameters
                Thank you.
                • A Offline
                  alex_ai @veye_xumm
                    veye_xumm @alex_ai
                    @alex_ai
                    • A Offline
                      alex_ai @veye_xumm
                      • A Offline
                        alex_ai @alex_ai
                        • A Offline
                          alex_ai @veye_xumm
                            veye_xumm @alex_ai
                            @alex_ai
                              veye_xumm
                              @alex_ai
                              • A Offline
                                alex_ai @veye_xumm
                                PS:
                                veye_xummV A 2 Replies Last reply Reply Quote 0
                                  veye_xumm @alex_ai
                                  @alex_ai
                                  • A Offline
                                    alex_ai @veye_xumm
                                    Yes, version is 1.09 after upgrade
                                    • A Offline
                                      alex_ai @alex_ai
                                      Finally tested, for gain value 20 it is looks pretty same with color sensor with ISP, but background no so black as for color sensor.
                                      For me this issue resolved, attached examples to compare (10 seconds stacks)
                                      IMX462 mono
                                      IMX462 color with ISP
