    IMX462M pixelformat on RPi5
    24 Posts 2 Posters 19.0k Views 1 Watching
    • A Offline
      alex_ai @veye_xumm
      Thank you for documentation, I used wrong algorithm to decode 10 bit packed format.
      According to doc:
      10-bit camera modes pack 4 pixels into 5 bytes. The first 4 bytes contain the 8 most significant bits (MSBs) of each pixel, and the final byte contains the 4 pairs of least significant bits (LSBs).
      I fixed it and can open raw image from python, but anyway need find way how to decode video in real time, because now decode one frame is about 3 seconds.
      Same Image as above:
        veye_xumm @alex_ai
        @alex_ai
        You did a great job.
        I have a plan to use the libcamera framework to support RAW-MIPI-IMX462M, but I haven't started yet. Once it is integrated with libcamera, it will be possible to use the picamera programs.
          veye_xumm @alex_ai
          @alex_ai
          To facilitate the application of the mv series cameras, we have released a beta version of the libcamera support package.
          It doesn't do isp tunning, so you can try it out. Please contact me if you have any questions.
          https://github.com/veyeimaging/libcamera
          https://github.com/veyeimaging/raspberrypi_v4l2
          • A Offline
            alex_ai @veye_xumm
            Hi, thank you for update.
            I'm stuck with compiling libcamera now, with same error as here : https://github.com/raspberrypi/libcamera/issues/151
            Did not find solution yet, probably need play with source code, will let you know if any updates.
              veye_xumm @alex_ai
              @alex_ai
              You can use the latest libpisp and try again.
              • A Offline
                alex_ai @veye_xumm
                Hi, it helped but I had to use 1.0.6 tag of libpisp, with the latest version I had compile errors.
                Now for command : rpicam-hello -v
                I have this error:
                I used set media script before:
                Maybe forgot something else.
                  veye_xumm @alex_ai
                  @alex_ai ./media_setting_rpi5**.sh is not necessary.
                  • A Offline
                    alex_ai @veye_xumm
                    Hi, I noticed that version of libcamera different on my screenshot (it 0.2.0 but I installed 0.3.0)
                    I uninstalled rpicam-apps and rebuild it from source code again and it uses my version of libcamera now.
                    if execute rpicam-still -v I have next error:
                    In commit I see added json file only to vc4 folder (for RPi4) , can we add it to pisp folder (for RPi5) it should have name : "mvcam_mono.json"? it has different format and can't use same file from vc4.
                    Also I managed start video by this command:
                    rpicam-still --tuning-file /source/libcamera/src/ipa/rpi/pisp/data/uncalibrated.json -t 0
                    and it works!
                    But better run it without additional parameters
                    Thank you.
                    • A Offline
                      alex_ai @veye_xumm
                        veye_xumm @alex_ai
                        @alex_ai
                        • A Offline
                          alex_ai @veye_xumm
                          • A Offline
                            alex_ai @alex_ai
                            • A Offline
                              alex_ai @veye_xumm
                                veye_xumm @alex_ai
                                @alex_ai
                                  veye_xumm
                                  @alex_ai
                                  • A Offline
                                    alex_ai @veye_xumm
                                    PS:
                                    veye_xummV A 2 Replies Last reply Reply Quote 0
                                      veye_xumm @alex_ai
                                      @alex_ai
                                      • A Offline
                                        alex_ai @veye_xumm
                                        Yes, version is 1.09 after upgrade
                                        • A Offline
                                          alex_ai @alex_ai
                                          Finally tested, for gain value 20 it is looks pretty same with color sensor with ISP, but background no so black as for color sensor.
                                          For me this issue resolved, attached examples to compare (10 seconds stacks)
                                          IMX462 mono
                                          IMX462 color with ISP
