    IMX462M pixelformat on RPi5
    24 Posts 2 Posters 19.8k Views 1 Watching
    • A Offline
      alex_ai @veye_xumm
        veye_xumm @alex_ai
        @alex_ai
        • A Offline
          alex_ai @veye_xumm
          • A Offline
            alex_ai @alex_ai
            • A Offline
              alex_ai @veye_xumm
                veye_xumm @alex_ai
                @alex_ai
                  veye_xumm
                  @alex_ai
                  • A Offline
                    alex_ai @veye_xumm
                    PS:
                    veye_xummV A 2 Replies Last reply Reply Quote 0
                      veye_xumm @alex_ai
                      @alex_ai
                      • A Offline
                        alex_ai @veye_xumm
                        Yes, version is 1.09 after upgrade
                        • A Offline
                          alex_ai @alex_ai
                          Finally tested, for gain value 20 it is looks pretty same with color sensor with ISP, but background no so black as for color sensor.
                          For me this issue resolved, attached examples to compare (10 seconds stacks)
                          IMX462 mono
                          IMX462 color with ISP
