    SC535M设置默认相机参数画面显示不正常的问题
    24 Posts 2 Posters 15.6k Views 1 Watching
      veye_xumm @Dangal
      @dangal
      你好,盲猜一个,你把下面这个函数的width变量也写作2560试一下。
      cap0.set(cv2.CAP_PROP_FRAME_WIDTH, args.width)
      • D Offline
        Dangal @veye_xumm
        jetson-tx2@ubuntu:/usr/local/src/nvidia_jetson_veye_bsp/samples/opencv/raw_camera$ cat 5wb-cam.py
        import cv2
        import argparse
        import subprocess
        def main():
            parser = argparse.ArgumentParser(description='Real-time display of GREY image from /dev/video0')
            parser.add_argument('--roix', type=int, default=0, help='roi start x (default: 0)')
            parser.add_argument('--roiy', type=int, default=0, help='roi start y (default: 0)')
            parser.add_argument('--width', type=int, default=2448, help='image width (default: 1280)')
            parser.add_argument('--height', type=int, default=2048, help='image height (default: 960)')
            parser.add_argument('--fps', type=int, default=30, help='frame rate (default: 30)')
            parser.add_argument('--preferred_stride', type=int, default=2560,help='preferred stride(default: 2560)')
            args = parser.parse_args()
            v4l2_cmd = "v4l2-ctl -d /dev/video0 --set-ctrl roi_x=%d" % args.roix
            subprocess.call(v4l2_cmd, shell=True)
            v4l2_cmd = "v4l2-ctl -d /dev/video0 --set-ctrl roi_y=%d" % args.roiy
            v4l2_cmd = "v4l2-ctl -d /dev/video0 --set-fmt-video=width=%d,height=%d,pixelformat=GREY" % (args.width,args.height)
            v4l2_cmd = "v4l2-ctl -d /dev/video0 --set-ctrl frame_rate=%d" % args.fps
            v4l2_cmd = "v4l2-ctl --set-ctrl preferred_stride=%d " % args.preferred_stride
            v4l2_cmd = "v4l2-ctl -d /dev/video1 --set-ctrl roi_x=%d" % args.roix
            v4l2_cmd = "v4l2-ctl -d /dev/video1 --set-ctrl roi_y=%d" % args.roiy
            v4l2_cmd = "v4l2-ctl -d /dev/video1 --set-fmt-video=width=%d,height=%d,pixelformat=GREY" % (args.width,args.height)
            v4l2_cmd = "v4l2-ctl -d /dev/video1 --set-ctrl frame_rate=%d" % args.fps
            v4l2_cmd = "v4l2-ctl -d /dev/video2 --set-ctrl roi_x=%d" % args.roix
            v4l2_cmd = "v4l2-ctl -d /dev/video2 --set-ctrl roi_y=%d" % args.roiy
            v4l2_cmd = "v4l2-ctl -d /dev/video2 --set-fmt-video=width=%d,height=%d,pixelformat=GREY" % (args.width,args.height)
            v4l2_cmd = "v4l2-ctl -d /dev/video2 --set-ctrl frame_rate=%d" % args.fps
            v4l2_cmd = "v4l2-ctl -d /dev/video3 --set-ctrl roi_x=%d" % args.roix
            v4l2_cmd = "v4l2-ctl -d /dev/video3 --set-ctrl roi_y=%d" % args.roiy
            v4l2_cmd = "v4l2-ctl -d /dev/video3 --set-fmt-video=width=%d,height=%d,pixelformat=GREY" % (args.width,args.height)
            v4l2_cmd = "v4l2-ctl -d /dev/video3 --set-ctrl frame_rate=%d" % args.fps
            v4l2_cmd = "v4l2-ctl -d /dev/video4 --set-ctrl roi_x=%d" % args.roix
            v4l2_cmd = "v4l2-ctl -d /dev/video4 --set-ctrl roi_y=%d" % args.roiy
            v4l2_cmd = "v4l2-ctl -d /dev/video4 --set-fmt-video=width=%d,height=%d,pixelformat=GREY" % (args.width,args.height)
            v4l2_cmd = "v4l2-ctl -d /dev/video4 --set-ctrl frame_rate=%d" % args.fps
            # Open the /dev/video0 device
            cap0 = cv2.VideoCapture('/dev/video0',cv2.CAP_V4L)
            cap1 = cv2.VideoCapture('/dev/video1',cv2.CAP_V4L)
            cap2 = cv2.VideoCapture('/dev/video2',cv2.CAP_V4L)
            cap3 = cv2.VideoCapture('/dev/video3',cv2.CAP_V4L)
            cap4 = cv2.VideoCapture('/dev/video4',cv2.CAP_V4L)
            if not cap0.isOpened():
                print("Failed to open /dev/video0")
                return
            if not cap1.isOpened():
                print("Failed to open /dev/video1")
                return
            if not cap2.isOpened():
                print("Failed to open /dev/video2")
                return
            if not cap3.isOpened():
                print("Failed to open /dev/video3")
                return
                print("Failed to open /dev/video4")
                return
            # Set the image size
            cap0.set(cv2.CAP_PROP_FRAME_WIDTH, 2560)
            cap0.set(cv2.CAP_PROP_FRAME_HEIGHT, args.height)
            cap1.set(cv2.CAP_PROP_FRAME_WIDTH, 2560)
            cap1.set(cv2.CAP_PROP_FRAME_HEIGHT, args.height)
            cap2.set(cv2.CAP_PROP_FRAME_WIDTH, 2560)
            cap2.set(cv2.CAP_PROP_FRAME_HEIGHT, args.height)
            cap3.set(cv2.CAP_PROP_FRAME_WIDTH, 2560)
            cap3.set(cv2.CAP_PROP_FRAME_HEIGHT, args.height)
            cap4.set(cv2.CAP_PROP_FRAME_WIDTH, 2560)
            cap4.set(cv2.CAP_PROP_FRAME_HEIGHT, args.height)
            # Calculate the aligned width
            #aligned_width = (args.width + 3)& ~3
            # Loop over frames and display them
            while True:
                # Read a frame
                ret0, frame0   = cap0.read()
                ret1, frame1   = cap1.read()
                ret2, frame2   = cap2.read()
                ret3, frame3   = cap3.read()
                ret4, frame4   = cap4.read()
                # Check if reading was successful
                if not ret0:
                    print("Failed to read frame from /dev/video0")
                    break
                if not ret1:
                    print("Failed to read frame from /dev/video1")
                    break
                if not ret2:
                    print("Failed to read frame from /dev/video2")
                    break
                if not ret3:
                    print("Failed to read frame from /dev/video3")
                    break
                if not ret4:
                    print("Failed to read frame from /dev/video4")
                    break
                #if frame.shape[1]!= aligned_width:
                #    aligned_frame = np.zeros((args.height, aligned_width), dtype=np.uint8)
                #    aligned_frame[:, args.width] = frame
                #    frame = aligned_frame
                # Display the frame
                cv2.imshow('preview (video0)', frame0)
                cv2.imshow('preview (video1)', frame1)
                cv2.imshow('preview (video2)', frame2)
                cv2.imshow('preview (video3)', frame3)
                cv2.imshow('preview (video4)', frame4)
                # Exit if 'q' key is pressed
                if cv2.waitKey(1) & 0xFF == ord('q'):
                    break
            # Release resources
            cap0.release()
            cap1.release()
            cap2.release()
            cap3.release()
            cap4.release()
            cv2.destroyAllWindows()
        if __name__ == '__main__':
            main()
        jetson-tx2@ubuntu:/usr/local/src/nvidia_jetson_veye_bsp/samples/opencv/raw_camera$ python 5wb-cam.py
        VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
        VIDIOC_STREAMON: Invalid argument
        这样修改之后 opencv就报错了 它不支持2560这样一个比较大的参数
        • D Offline
          Dangal @veye_xumm
          @veye_xumm 我猜,应该是 opencv它获取了sensor的最大宽度,你不能设置比它传感器更大的宽度,因为2448是可以设置的,但是显示不正常,我把width设置成2304,也是可以的
            veye_xumm @Dangal
            @dangal
            opencv库对于这种内存对齐的特殊处理不完善。建议你如果想使用opencv开发,就用256的整数倍作为width。
            使用c/c++可以结合prefer stride,不受此限制。
            • D Offline
              Dangal @veye_xumm
              在测量过程中,还存在一个问题,即设置了v4l2-ctl的这些参数后 只有第一路/dev/video0 是不正常的,其他路都是正常的,开始怀疑是摄像头的问题,但是发现对调后仍然是/dev/video0 显示不正常,看起来就像是参数设置没有生效一样 但实际用opencv的show_grey.py例程 /dev/video0是显示正常的 是这些参数有什么先后顺序的问题吗?我也调整过参数的设置顺序,但还是会出现问题
              D veye_xummV 2 Replies Last reply Reply Quote 0
              • D Offline
                Dangal @Dangal
                现在有一个问题就是opencv无法设置到2560,我试过了 如果v4l2设置了2448,但是opencv宽度改成2304,那么用qv4l2打开发现,最后的宽度还是2304,现在有个问题是我这边需要大于500w像素,24482048=5013504,但是这个在jetson系列上显示不正常,如果用v4l2-ctl的话,则它只能抓一帧存到本地文件里,无法达到实时预览的效果,2304虽然正常,但是23042048=4718592,和我想要达到大于500w还是有一定的差距.
                如果用c++开发,能不能提供c++的例程或者是相关SDK?
                  veye_xumm @Dangal
                  @dangal 注意下你的v4l2-ctl 需使用 -d /dev/video* 参数来指明配置到哪个摄像头。
                    veye_xumm @Dangal
                    @dangal 参考一下8.1和8.2 https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_jetson/zh#Application_demo
                    • D Offline
                      Dangal @veye_xumm
                      你好 在使用了
                      v4l2-ctl -d /dev/video3 --set-ctrl preferred_stride=2560 --set-fmt-video=width=2448,height=2048,pixelformat=GREY --stream-mmap --stream-count=30 --stream-to=v3.raw
                      之后,我得到了v3.raw,然后我发现效果像是preferred_stride设置并没有生效
                        veye_xumm @Dangal
                        • D Offline
                          Dangal @veye_xumm
                          @veye_xumm 我按照2448*2048预览的
                          文件大小一共150M 我抓了30帧 所以一张是5M
                          一张是5242880字节
                            veye_xumm @Dangal
                            @dangal
                            你还是没有理解stride的意思。
                            • D Offline
                              Dangal @veye_xumm
                              got it!
                              • D Offline
                                Dangal @veye_xumm
                                  veye_xumm @Dangal
                                  @dangal
                                  比如改成64
                                  • D Offline
                                    Dangal @veye_xumm
                                      veye_xumm @Dangal
                                      @dangal
                                      • D Offline
                                        Dangal @veye_xumm
                                          veye_xumm @Dangal
                                          • D Offline
                                            Dangal @veye_xumm
