    移植imx462摄像头驱动到rk3588时出现了以下的问题,不知道怎么解决,内核版本是5.10
    29 Posts 2 Posters 18.0k Views 1 Watching
    • A Offline
      aike
      rk3588-veyecam2m.txt 这是摄像头接口的原理图(Uploading 100%) f0353728-900d-476b-9ac1-4841d167dc32-image.png
      v4l2-ctl --list-device
      rk_hdmirx (fdee0000.hdmirx-controller):
      /dev/video20
      rkisp-statistics (platform: rkisp):
      /dev/video18
      /dev/video19
      rkcif-mipi-lvds2 (platform:rkcif):
      /dev/media0
      rkisp_mainpath (platform:rkisp0-vir2):
      /dev/video11
      /dev/video12
      /dev/video13
      /dev/video14
      /dev/video15
      /dev/video16
      /dev/video17
      /dev/media1
      Failed to open /dev/video0: No such device
      接口配对关系.txt
      请问哪个node没有没有配对呢
        veye_xumm @aike
        @aike
        第一步,i2c要调通。上次你曾经调好过。
        第二步,dts中关于mipi接口的节点连接关系要写对。你这个原理图是外设接插件的,并没有能表明最终接入到3588用的是哪几个接口。
        如果这个板子本身有默认支持的camera,比如ov5640之类的,你可以 参考那个dts。
        或者你把这个板子原生支持的摄像头的dts和你现在移植的VEYE模组的dts都发出来,我帮你看看。
        • A Offline
          aike
          这是原生支持的imx219摄像头,我是用camera3和camera4[0_1733196166905_tl3588-evm-imx219.dts](Uploading 100%)
          这是veye模组的摄像头rk3588-veyecam2m.txt veye模组的摄像头也需要用两个,也就是camera3和camera4,目前只是在调试camera3接口,
          • A Offline
            aike
            刚刚dts文件没有传上去,我用txt再传输一边imx219摄像头的dts
            tl3588-evm-imx219.txt
              veye_xumm @aike
              @aike 你现在i2c是通的,能识别到摄像头型号,对吗?
              • A Offline
                aike
                  veye_xumm @aike
                  @aike 试试这个
                  #include "tl3588-evm.dts"
                  &i2c1 {
                          status = "okay";
                          // pinctrl-names = "default";
                          veyecam2m: veyecam2m@3b{
                                 reg = <0x3b>;
                  	           clock-names = "xvclk";
                                 status = "okay";
                                 port {
                                          veyecam2m_out0: endpoint {
                                                 data-lanes = <1 2>;
                  &csi2_dphy0_hw {
                  	status = "okay";
                  &csi2_dphy1 {
                  	status = "okay";
                  	ports {
                  		#address-cells = <1>;
                  		#size-cells = <0>;
                  		port@0 {
                  			reg = <0>;
                  			#size-cells = <0>;
                  				reg = <1>;
                  				data-lanes = <1 2>;
                  		port@1 {
                  			reg = <1>;
                  			#size-cells = <0>;
                  			csidphy1_out: endpoint@0 {
                  				reg = <0>;
                  &mipi2_csi2_hw {
                          status = "okay";
                  &mipi2_csi2 {
                  	status = "okay";
                  	ports {
                  		#size-cells = <0>;
                  		port@0 {
                  			reg = <0>;
                  			#size-cells = <0>;
                  				reg = <1>;
                  		port@1 {
                  			reg = <1>;
                  			#size-cells = <0>;
                  				reg = <0>;
                  &rkcif_mipi_lvds2 {
                  	status = "okay";
                  	firefly,yuv_camera;
                  	port {
                  		cif_mipi2_in0: endpoint {
                  &rkcif_mipi_lvds2_sditf {
                  	status = "disabled";
                  	port {
                  		mipi_lvds2_sditf: endpoint {
                  &rkisp0_vir2 {
                  	port {
                  		#size-cells = <0>;
                  		isp0_vir2: endpoint@0 {
                  			reg = <0>;
                  &gpio2 {
                          pinctrl-0 = <&mipidphy0_pwr>;
                          camera3-pwdn-set {
                                  gpio-hog;
                                  output-high;
                  &pinctrl {
                  	cam {
                  			rockchip,pins =
                  				/* camera power en */
                  &rkcif {
                  	status = "okay";
                  &rkcif_mmu {
                  	status = "okay";
                  &rkisp0 {
                  &isp0_mmu {
                  • A Offline
                    aike
                      veye_xumm @aike
                      关于dts的逻辑关系,你可以参考这篇文章。
                      • A Offline
                        aike
                        摄像头拓扑结构图
                        摄像头拓扑结构图.txt
                        抓取图片也有问题
                        • A Offline
                          aike
                          这是什么情况呢
                            veye_xumm @aike
                            • A Offline
                              aike
                              同时串口会打印这些
                              请问这个问题怎么解决
                                veye_xumm @aike
                                • A Offline
                                  aike
                                    veye_xumm @aike
                                    @aike 可能性很小。你试试用这个脚本抓一下图:
                                    • A Offline
                                      aike
                                      • A Offline
                                        aike
                                        nv12-1920x1080.yuv里面是空的
                                          veye_xumm @aike
                                          @aike
                                          你试一下将驱动中下面这个函数改成如下:
                                              VEYE_TRACE
                                          		return -EINVAL;
                                          	//	return -EINVAL;
                                          	return 0;
                                          然后重新编译一下再测测。
                                          • A Offline
                                            aike
                                            还是一样的错误
