    移植imx462摄像头驱动到rk3588时出现了以下的问题,不知道怎么解决,内核版本是5.10
    29 Posts 2 Posters 18.0k Views 1 Watching
    • A Offline
      aike
      刚刚dts文件没有传上去,我用txt再传输一边imx219摄像头的dts
      tl3588-evm-imx219.txt
        veye_xumm @aike
        @aike 你现在i2c是通的,能识别到摄像头型号,对吗?
        • A Offline
          aike
            veye_xumm @aike
            @aike 试试这个
            #include "tl3588-evm.dts"
            &i2c1 {
                    status = "okay";
                    // pinctrl-names = "default";
                    veyecam2m: veyecam2m@3b{
                           reg = <0x3b>;
            	           clock-names = "xvclk";
                           status = "okay";
                           port {
                                    veyecam2m_out0: endpoint {
                                           data-lanes = <1 2>;
            &csi2_dphy0_hw {
            	status = "okay";
            &csi2_dphy1 {
            	status = "okay";
            	ports {
            		#address-cells = <1>;
            		#size-cells = <0>;
            		port@0 {
            			reg = <0>;
            			#size-cells = <0>;
            				reg = <1>;
            				data-lanes = <1 2>;
            		port@1 {
            			reg = <1>;
            			#size-cells = <0>;
            			csidphy1_out: endpoint@0 {
            				reg = <0>;
            &mipi2_csi2_hw {
                    status = "okay";
            &mipi2_csi2 {
            	status = "okay";
            	ports {
            		#size-cells = <0>;
            		port@0 {
            			reg = <0>;
            			#size-cells = <0>;
            				reg = <1>;
            		port@1 {
            			reg = <1>;
            			#size-cells = <0>;
            				reg = <0>;
            &rkcif_mipi_lvds2 {
            	status = "okay";
            	firefly,yuv_camera;
            	port {
            		cif_mipi2_in0: endpoint {
            &rkcif_mipi_lvds2_sditf {
            	status = "disabled";
            	port {
            		mipi_lvds2_sditf: endpoint {
            &rkisp0_vir2 {
            	port {
            		#size-cells = <0>;
            		isp0_vir2: endpoint@0 {
            			reg = <0>;
            &gpio2 {
                    pinctrl-0 = <&mipidphy0_pwr>;
                    camera3-pwdn-set {
                            gpio-hog;
                            output-high;
            &pinctrl {
            	cam {
            			rockchip,pins =
            				/* camera power en */
            &rkcif {
            	status = "okay";
            &rkcif_mmu {
            	status = "okay";
            &rkisp0 {
            &isp0_mmu {
            • A Offline
              aike
                veye_xumm @aike
                关于dts的逻辑关系,你可以参考这篇文章。
                • A Offline
                  aike
                  摄像头拓扑结构图
                  摄像头拓扑结构图.txt
                  抓取图片也有问题
                  • A Offline
                    aike
                    这是什么情况呢
                      veye_xumm @aike
                      • A Offline
                        aike
                        同时串口会打印这些
                        请问这个问题怎么解决
                          veye_xumm @aike
                          • A Offline
                            aike
                              veye_xumm @aike
                              @aike 可能性很小。你试试用这个脚本抓一下图:
                              • A Offline
                                aike
                                • A Offline
                                  aike
                                  nv12-1920x1080.yuv里面是空的
                                    veye_xumm @aike
                                    @aike
                                    你试一下将驱动中下面这个函数改成如下:
                                        VEYE_TRACE
                                    		return -EINVAL;
                                    	//	return -EINVAL;
                                    	return 0;
                                    然后重新编译一下再测测。
                                    • A Offline
                                      aike
                                      还是一样的错误
                                        veye_xumm @aike
