    移植imx462摄像头驱动到rk3588时出现了以下的问题,不知道怎么解决,内核版本是5.10
    29 Posts 2 Posters 18.0k Views 1 Watching
      veye_xumm @aike
      @aike 试试这个
      #include "tl3588-evm.dts"
      &i2c1 {
              status = "okay";
              // pinctrl-names = "default";
              veyecam2m: veyecam2m@3b{
                     reg = <0x3b>;
      	           clock-names = "xvclk";
                     status = "okay";
                     port {
                              veyecam2m_out0: endpoint {
                                     data-lanes = <1 2>;
      &csi2_dphy0_hw {
      	status = "okay";
      &csi2_dphy1 {
      	status = "okay";
      	ports {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      				reg = <1>;
      				data-lanes = <1 2>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      			csidphy1_out: endpoint@0 {
      				reg = <0>;
      &mipi2_csi2_hw {
              status = "okay";
      &mipi2_csi2 {
      	status = "okay";
      	ports {
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      				reg = <1>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      				reg = <0>;
      &rkcif_mipi_lvds2 {
      	status = "okay";
      	firefly,yuv_camera;
      	port {
      		cif_mipi2_in0: endpoint {
      &rkcif_mipi_lvds2_sditf {
      	status = "disabled";
      	port {
      		mipi_lvds2_sditf: endpoint {
      &rkisp0_vir2 {
      	port {
      		#size-cells = <0>;
      		isp0_vir2: endpoint@0 {
      			reg = <0>;
      &gpio2 {
              pinctrl-0 = <&mipidphy0_pwr>;
              camera3-pwdn-set {
                      gpio-hog;
                      output-high;
      &pinctrl {
      	cam {
      			rockchip,pins =
      				/* camera power en */
      &rkcif {
      	status = "okay";
      &rkcif_mmu {
      	status = "okay";
      &rkisp0 {
      &isp0_mmu {
      • A Offline
        aike
          veye_xumm @aike
          关于dts的逻辑关系,你可以参考这篇文章。
          • A Offline
            aike
            摄像头拓扑结构图
            摄像头拓扑结构图.txt
            抓取图片也有问题
            • A Offline
              aike
              这是什么情况呢
                veye_xumm @aike
                • A Offline
                  aike
                  同时串口会打印这些
                  请问这个问题怎么解决
                    veye_xumm @aike
                    • A Offline
                      aike
                        veye_xumm @aike
                        @aike 可能性很小。你试试用这个脚本抓一下图:
                        • A Offline
                          aike
                          • A Offline
                            aike
                            nv12-1920x1080.yuv里面是空的
                              veye_xumm @aike
                              @aike
                              你试一下将驱动中下面这个函数改成如下:
                                  VEYE_TRACE
                              		return -EINVAL;
                              	//	return -EINVAL;
                              	return 0;
                              然后重新编译一下再测测。
                              • A Offline
                                aike
                                还是一样的错误
                                  veye_xumm @aike
