    Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    29 Posts 2 Posters 15.1k Views 1 Watching
    • J Offline
      jambojettt
      https://forum.veye.cc/topic/358/please-update-the-v4l2-driver-for-5-15-84-v7l
      Followed this, when compiling dtb the error pops up
      ![alt text](c07f9324-c61b-4227-80f0-d2da4621d91e-изображение.png image url)
      Trying to install headers didn't work, manually copied and created the directories, still an error
      dmesg doesn't work (doesn't say anything. Camera worked before with Legacy mode.
      ![alt text](bada1a01-c29c-4829-98d0-7bbd0cc2e727-изображение.png image url)
      do I need to recompile on ubuntu? I don't have one installed, don't have spare pc or laptop.
      I want to use it with opencv and yolov3tiny for bug detection.
        veye_xumm @jambojettt
        @jambojettt According to the dmesg information, you have successfully installed the veyecam2m driver. However, the camera was not detected. What model of camera are you using?
        • J Offline
          jambojettt @veye_xumm
          @veye_xumm veye-mipi327e
            @jambojettt
            Normally, after you install the kernel headers using the command sudo apt install raspberrypi-kernel-headers, you should be able to compile successfully.
            May I ask — after performing this step, what error do you see during compilation?
            • J Offline
              @veye_xumm this didn't work, I updated the raspi-config to the latest one, this command didn't work. Tried this several times to no avail.
              • J Offline
                jambojettt @jambojettt
                  @jambojettt
                  Sorry for the slightly delayed reply. Normally, piOS comes with kernel-headers pre-installed. For example, here is a screenshot of my current system:
                  I suspect that you might have updated to a newer minor version of piOS, which caused this issue. The current major version of piOS should be 6.12.47.
                    • J Offline
                      @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
                      How do I get the headers?
                        @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
                        My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
                        • J Offline
                          • J Offline
                            Kernel headers are installed.
                            • J Offline
                                @jambojettt
                                uname -a
                                ls /usr/lib/modules/
                                • J Offline
                                    @jambojettt
                                    Sorry for reply late.
                                    • J Offline
                                      make
                                      reinstalled by github
                                      Which one do I use?
                                        @jambojettt
                                        • J Offline
                                            @jambojettt
                                            dmesg | grep veye
