    saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    28 Posts 2 Posters 13.1k Views 1 Watching
    • W Offline
      watchever
      @veye_xumm, thanks for answer. Is there any possibility to set camera params by using a structure from libdmipicam.so rather than using shell script.
        veye_xumm @watchever
        @watchever
        We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
        It should be able to implement the method you are talking about.
        • W Offline
          watchever
          @veye_xumm,
          Ok I am going to implement this in C language.
          However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
          I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
          Thanks for your help
          • W Offline
            watchever
              @watchever
              yes.
              • W Offline
                watchever
                • W Offline
                  watchever
                  • W Offline
                    watchever
                      RaspiCamControl
                      I think it could not work.
                      • W Offline
                        watchever
                          @watchever
                          • W Offline
                            watchever
                              @watchever
                              NO.
                              • W Offline
                                watchever
                                And Yuv420 of course ?
                                  Yuv420 of course ?
                                  no,just yuv422
                                  • W Offline
                                    watchever
                                      @watchever
                                      These are software functions.
                                      • W Offline
                                        watchever
                                          @watchever
                                          For yuv ,
