    saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    28 Posts 2 Posters 12.6k Views 1 Watching
    • W Offline
      watchever
      @veye_xumm, thanks a lot for you quick answer.
      I was using PiCamera python package to access the new HQ RaspiCam with IMX477 sensor.
      From there, you can easily set dynamicaly saturation, contrats (there are set_contrast, set_saturation functions),which is a bit cleaner than using sh scripts. Do you think it is possible to add such functions in your D_mipicam.c file and call them from Python ?
      If not I will call the shell script.
      Regarding the overlay, as I work in full terminal mode (no xwindow), I was wondering if it was possible to display a (for example) jpg image using your API ? I know that MMAL can do that with overlay renderer.
      And other questions for you 🙂 :
      • As PiCamera is a python package that fully rely on MMAL, do you know if it can work with your VEYE-IMX462 camera ?
      • Is it possible from your API to convert a capture to a numpy array. I think that's what asarray method in buffer doing but not sure.
      Thanks for your precious help
      Regards
      • W Offline
        watchever
        And does the source code of libveyecam.a library available somewhere ?
        • W Offline
          watchever
          And sorry another question. If I set saturation, contrast from this script (through Python), and then make a capture from mipi_camera instance in my python program will it use my saturation, contrast setting to make the capture ?
            veye_xumm @watchever
            @watchever This is not open for the time being, sorry.
              @watchever
              yes
                @watchever
                I think it could not work.
                • W Offline
                  watchever
                  @veye_xumm, thanks for answer. Is there any possibility to set camera params by using a structure from libdmipicam.so rather than using shell script.
                    @watchever
                    We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
                    It should be able to implement the method you are talking about.
                    • W Offline
                      watchever
                      @veye_xumm,
                      Ok I am going to implement this in C language.
                      However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
                      I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
                      Thanks for your help
                      • W Offline
                        watchever
                          @watchever
                          yes.
                          • W Offline
                            watchever
                            • W Offline
                              watchever
                              • W Offline
                                watchever
                                  RaspiCamControl
                                  • W Offline
                                    watchever
                                      @watchever
                                      • W Offline
                                        watchever
                                          @watchever
                                          NO.
                                          • W Offline
                                            watchever
                                            And Yuv420 of course ?
