    saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    28 Posts 2 Posters 10.9k Views 1 Watching
    • W Offline
      watchever
      Hello, is it possible to set saturation, contrast, shutter speed and iso of camera module VEYE-MIPI-290 during preview in python language ?
      And is it possible to display image from a file like overlay ?
      Thanks for your help
      • W Offline
        watchever @watchever
        I mean module VEYE-MIPI-462
          veye_xumm @watchever
          @watchever
          Yes, You can use this shell script :
          http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/
          I don't quite understand what you mean. Could you elaborate on it?
          • W Offline
            watchever
            @veye_xumm, thanks a lot for you quick answer.
            I was using PiCamera python package to access the new HQ RaspiCam with IMX477 sensor.
            From there, you can easily set dynamicaly saturation, contrats (there are set_contrast, set_saturation functions),which is a bit cleaner than using sh scripts. Do you think it is possible to add such functions in your D_mipicam.c file and call them from Python ?
            If not I will call the shell script.
            Regarding the overlay, as I work in full terminal mode (no xwindow), I was wondering if it was possible to display a (for example) jpg image using your API ? I know that MMAL can do that with overlay renderer.
            And other questions for you 🙂 :
            • As PiCamera is a python package that fully rely on MMAL, do you know if it can work with your VEYE-IMX462 camera ?
            • Is it possible from your API to convert a capture to a numpy array. I think that's what asarray method in buffer doing but not sure.
            Thanks for your precious help
            Regards
            • W Offline
              watchever
              And does the source code of libveyecam.a library available somewhere ?
              • W Offline
                watchever
                And sorry another question. If I set saturation, contrast from this script (through Python), and then make a capture from mipi_camera instance in my python program will it use my saturation, contrast setting to make the capture ?
                  @watchever This is not open for the time being, sorry.
                    @watchever
                    yes
                      @watchever
                      I think it could not work.
                      • W Offline
                        watchever
                        @veye_xumm, thanks for answer. Is there any possibility to set camera params by using a structure from libdmipicam.so rather than using shell script.
                          @watchever
                          We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
                          It should be able to implement the method you are talking about.
                          • W Offline
                            watchever
                            @veye_xumm,
                            Ok I am going to implement this in C language.
                            However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
                            I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
                            • W Offline
                              watchever
                                @watchever
                                yes.
                                • W Offline
                                  watchever
                                  • W Offline
                                    watchever
                                    • W Offline
                                      watchever
                                        RaspiCamControl
                                        • W Offline
                                          watchever
                                            @watchever
