    saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    28 Posts 2 Posters 12.6k Views 1 Watching
    • W Offline
      watchever
      And sorry another question. If I set saturation, contrast from this script (through Python), and then make a capture from mipi_camera instance in my python program will it use my saturation, contrast setting to make the capture ?
        veye_xumm @watchever
        @watchever This is not open for the time being, sorry.
          @watchever
          yes
            @watchever
            As PiCamera is a python package that fully rely on MMAL, do you know if it can work with your VEYE-IMX462 camera ?
            I think it could not work.
            • W Offline
              watchever
              @veye_xumm, thanks for answer. Is there any possibility to set camera params by using a structure from libdmipicam.so rather than using shell script.
                @watchever
                We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
                It should be able to implement the method you are talking about.
                • W Offline
                  watchever
                  @veye_xumm,
                  Ok I am going to implement this in C language.
                  However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
                  I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
                  Thanks for your help
                  • W Offline
                    watchever
                      @watchever
                      yes.
                      • W Offline
                        watchever
                        • W Offline
                          watchever
                          • W Offline
                            watchever
                              RaspiCamControl
                              • W Offline
                                watchever
                                  @watchever
                                  • W Offline
                                    watchever
                                      @watchever
                                      NO.
                                      • W Offline
                                        watchever
                                        And Yuv420 of course ?
                                          Yuv420 of course ?
                                          no,just yuv422
                                          • W Offline
                                            watchever
