    2. meontechno
    M
    Offline
    • Topics 2
    • Posts 6
    meontechno
    @meontechno
    Joined
    Last Online
    Email dekkidalto@gufum.com
    meontechno Unfollow Follow
    Latest posts made by meontechno
    • RE: VEYE IMX-307 MIPI CSI camera drivers not working on Jetpack 5.0.2
      Hi,
      We are using Orin 32G and we have installed the jetpack on Nvme M.2 ssd. We will remove the ssd and try installing it in emmc storage.
      posted in Jetson App Software
      M
      meontechno
    • RE: VEYE IMX-307 MIPI CSI camera Freeze and Interference Issue
      Hello,
      Thanks for the reply. We will check with a different FFC cable and give you updates.
      M
      meontechno
      Hello, we executed these commands and here's the output.
      $ ls /lib/modules/$(uname -r)/kernel/drivers/media/i2c/
      cs_imx307.ko  max96712.ko      nv_imx219.ko  nv_imx477.ko    nv_ov5693.ko  veyecam.ko
      cs_sc132.ko   nv_ar0234.ko     nv_imx268.ko  nv_lc898212.ko  nv_ov9281.ko  veye_imx335.ko
      ds90ub954.ko  nv_imx185.ko     nv_imx274.ko  nv_ov10823.ko   pca9570.ko    veye_mvcam.ko
      lt6911uxc.ko  nv_imx185_v1.ko  nv_imx318.ko  nv_ov23850.ko   tc358840.ko
      $ md5sum /lib/modules/$(uname -r)/kernel/drivers/media/i2c/cs_imx307.ko
      81417093cd05f335b5cae412481219ba  /lib/modules/5.10.104-tegra/kernel/drivers/media/i2c/cs_imx307.ko
      $ md5sum /boot/veyecam/tegra234-p3701-0000-p3737-0000.dtb
      32b4415fe4456e0248784c53b14e2bd1  /boot/veyecam/tegra234-p3701-0000-p3737-0000.dtb
      $ sudo dmesg | grep DT
      [sudo] password for orin-prod1:
      [    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022
      [    0.000000] psci: probing for conduit method from DT.
      [    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
      [    0.003748] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
      [    0.003801] DTB Build time: Sep 28 2022 00:08:47
      [    1.830156] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
      [   12.649339] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  35.1.0  Release Build  (buildbrain@mobile-u64-5273-d7000)  Wed Aug 10 20:32:39 PDT 2022
      [   13.991594] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
      [   26.088242] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.1.0  Release Build  (buildbrain@mobile-u64-5273-d7000)  Wed Aug 10 20:32:41 PDT 2022
      M
      meontechno
    • VEYE IMX-307 MIPI CSI camera Freeze and Interference Issue
      Hello,
      We are using IMX-307 CSI cameras and we are facing some freezing and interference issues (Image captured by the camera has some colored lines in random spots).
      1. Camera freezes randomly and the image is stuck at a certain point and we have to re run the program or reboot the system to fix it. Only one of the 3 cameras we are using has this freezing issue.
      2. Interference appears randomly. However, it only lasts for few seconds and goes away.
      Here's an image without interference -
      Same image with interference -
      Need help looking into these issues. Thanks
      M
      meontechno
      Here's terminal output of the commands that we executed for installing the drivers following the documentation. You can see in the below screenshot that we are installing correction version drivers for Jetpack 5.0.2.
      Here's the updated content of /boot/extlinux/extlinux.conf
      After installation we rebooted the system and executed the below commands (Section 3.7)
      M
      meontechno
    • VEYE IMX-307 MIPI CSI camera drivers not working on Jetpack 5.0.2
      We are using VEYE IMX-307 MIPI CSI camera and camera interposer module (http://www.veye.cc/en/product/cs-tx2-xavier-ncam-imx307/) with Jetson Orin 32GB. Here’s the link to the camera drivers - (http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2)
      Interposer module and the cameras were working perfectly fine with Jetpack 5.0.1 DP. We followed the below steps -
      However, Jetpack 5.0.1 DP has been discontinued by Nvidia. With Jetpack 5.0.2, we are able to install camera and the interposer module drivers without any errors. However the system is unable to recognize the interposer module and the cameras (Verification steps in shown in the picture above gives not output).
      Need assistance in installation of drivers in Jetpack 5.0.2.
      M
      meontechno
