    SOLVED CSI132相机nvidia nx平台上无法更新硬件
    8201
    • Z
      zjutony last edited by
      我的板子是nvidia nx ,系统版本是32.6.1,按照http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2/zh中的教程,将对应的Image_l4t_r32.6.1_veyecam_signed_4_xavier.tgz和Image_l4t_r32.6.1_veyecam.tar,gz 解压缩以后的Image和Image.sig拷贝到/boot 下并将对应的tegra194-p3668-all-p3509-0000.dtb也考到boot下了,下面是boot下的内容
      ls /boot/
      dtb
      extlinux
      grub
      Image.sig
      Image.t19x
      Image.t19x.sig
      initrd
      initrd.img
      initrd.img-4.9.253-tegra
      initrd.sig
      initrd.t19x
      initrd.t19x.sig
      kernel_tegra194-p3668-all-p3509-0000.dtb
      tegra186-p3636-0001-p3509-0000-a01-adafruit-sph0645lm4h.dtbo
      tegra186-p3636-0001-p3509-0000-a01-adafruit-uda1334a.dtbo
      tegra186-p3636-0001-p3509-0000-a01.dtb
      tegra186-p3636-0001-p3509-0000-a01-fe-pi-audio.dtbo
      tegra186-p3636-0001-p3509-0000-a01-hdr40.dtbo
      tegra186-p3636-0001-p3509-0000-a01-m2ke.dtbo
      tegra186-p3636-0001-p3509-0000-a01-respeaker-4-mic-array.dtbo
      tegra186-p3636-0001-p3509-0000-a01-respeaker-4-mic-lin-array.dtbo
      tegra186-quill-p3310-1000-a00-00-base.dtb
      tegra186-quill-p3310-1000-as-0888.dtb
      tegra186-quill-p3310-1000-c03-00-base-adafruit-sph0645lm4h.dtbo
      tegra186-quill-p3310-1000-c03-00-base-adafruit-uda1334a.dtbo
      tegra186-quill-p3310-1000-c03-00-base-csi.dtbo
      tegra186-quill-p3310-1000-c03-00-base.dtb
      tegra186-quill-p3310-1000-c03-00-base-fe-pi-audio.dtbo
      tegra186-quill-p3310-1000-c03-00-base-hdr30.dtbo
      tegra186-quill-p3310-1000-c03-00-base-hdr40.dtbo
      tegra186-quill-p3310-1000-c03-00-base-m2ke.dtbo
      tegra186-quill-p3310-1000-c03-00-base-respeaker-4-mic-array.dtbo
      tegra186-quill-p3310-1000-c03-00-base-respeaker-4-mic-lin-array.dtbo
      tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dtb
      tegra186-quill-p3489-0888-a00-00-base.dtb
      tegra186-quill-p3489-1000-a00-00-ucm1.dtb
      tegra186-quill-p3489-1000-a00-00-ucm2.dtb
      tegra194-p2888-0001-p2822-0000-adafruit-sph0645lm4h.dtbo
      tegra194-p2888-0001-p2822-0000-adafruit-uda1334a.dtbo
      tegra194-p2888-0001-p2822-0000-csi.dtbo
      tegra194-p2888-0001-p2822-0000.dtb
      tegra194-p2888-0001-p2822-0000.dtb.sig
      tegra194-p2888-0001-p2822-0000-fe-pi-audio.dtbo
      tegra194-p2888-0001-p2822-0000-hdr40.dtbo
      tegra194-p2888-0001-p2822-0000-m2ke.dtbo
      tegra194-p2888-0001-p2822-0000-maxn.dtb
      tegra194-p2888-0001-p2822-0000-maxn.dtb.sig
      tegra194-p2888-0001-p2822-0000-respeaker-4-mic-array.dtbo
      tegra194-p2888-0001-p2822-0000-respeaker-4-mic-lin-array.dtbo
      tegra194-p2888-0004-e3900-0000-adafruit-sph0645lm4h.dtbo
      tegra194-p2888-0004-e3900-0000-adafruit-uda1334a.dtbo
      tegra194-p2888-0004-e3900-0000-csi.dtbo
      tegra194-p2888-0004-e3900-0000.dtb
      tegra194-p2888-0004-e3900-0000.dtb.sig
      tegra194-p2888-0004-e3900-0000-dual-imx274.dtbo
      tegra194-p2888-0004-e3900-0000-fe-pi-audio.dtbo
      tegra194-p2888-0004-e3900-0000-hdr40.dtbo
      tegra194-p2888-0004-e3900-0000-imx274.dtbo
      tegra194-p2888-0004-e3900-0000-respeaker-4-mic-array.dtbo
      tegra194-p2888-0004-e3900-0000-respeaker-4-mic-lin-array.dtbo
      tegra194-p2888-0008-p2822-0000.dtb
      tegra194-p2888-0008-p2822-0000.dtb.sig
      tegra194-p2888-as-0006-p2822-0000.dtb
      tegra194-p2888-as-0006-p2822-0000.dtb.sig
      tegra194-p2888-as-p3668-p2822-0000.dtb
      tegra194-p2888-as-p3668-p2822-0000.dtb.sig
      tegra194-p3668-all-p3509-0000-adafruit-sph0645lm4h.dtbo
      tegra194-p3668-all-p3509-0000-adafruit-uda1334a.dtbo
      tegra194-p3668-all-p3509-0000-camera-imx219-dual.dtbo
      tegra194-p3668-all-p3509-0000-camera-imx477-dual.dtbo
      tegra194-p3668-all-p3509-0000-camera-imx477-imx219.dtbo
      tegra194-p3668-all-p3509-0000.dtb.sig
      tegra194-p3668-all-p3509-0000-fe-pi-audio.dtbo
      tegra194-p3668-all-p3509-0000-hdr40.dtbo
      tegra194-p3668-all-p3509-0000-m2ke.dtbo
      tegra194-p3668-all-p3509-0000-respeaker-4-mic-array.dtbo
      tegra194-p3668-all-p3509-0000-respeaker-4-mic-lin-array.dtbo
      但是reboot以后,在设备树下只发现了imx219和imx477
      nvidia@nvidia-desktop:/home$ ls /proc/device-tree/cam_i2cmux/i2c@
      i2c@0/ i2c@1/
      nvidia@nvidia-desktop:/home$ ls /proc/device-tree/cam_i2cmux/i2c@0
      '#address-cells' name rbpcv2_imx219_a@10 reg
      linux,phandle phandle rbpcv3_imx477_a@1a '#size-cells'
      nvidia@nvidia-desktop:/home$ ls /proc/device-tree/cam_i2cmux/i2c@1
      '#address-cells' name rbpcv2_imx219_c@10 reg
      linux,phandle phandle rbpcv3_imx477_c@1a '#size-cells'
      这个是/sys/bus/i2c/drivers/下也找不到对应的相机目录,
      nvidia@nvidia-desktop:/home$ ls /sys/bus/i2c/drivers
      bmi160_i2c imx318 lc898212 max9296 pca954x sgtl5000 ucsi_ccg
      bq27xxx-battery imx390 lm92 nct1008_nct72 pca9570 stepper_pca usb3503
      cs53l30 imx477 lp855x ov10823 'PEX9749 thermal sensor' tas2552
      dummy ina219x lt6911uxc ov23850 rt5640 tegra_edid
      imx219 ina230x max77620 ov9281 rt5659 tmpm32xi2c
      imx268 ina3221x max9295 pca953x rtc-rx8025 tps65132
      是我哪里操作不对嘛,没法更新Image和DTB
        veye_xumm @zjutony last edited by
        @zjutony
        你好,Image只用signed的包压缩出来的。Image_l4t_r32.6.1_veyecam_signed_4_xavier.tgz
        dtb放进去之后,记得要改一下
        编辑 /boot/extlinux/extlinux.conf文件。
        part 3.6.4
        • Z
          zjutony @veye_xumm last edited by
          @veye_xumm 这个我已经改了
          • Z
            @veye_xumm 更新的时候需要插着相机嘛,我更新的时候没有插相机
              @zjutony
              更新的时候不需要。
                @zjutony 最近有两个人都跟我反馈此问题了。请问你的原生系统,是通过nvidia提供的镜像烧写的,还是通过sdkmanager烧进去的?
                  @zjutony 可否把你的
                  dmesg
                  提示信息保存到一个txt,作为附件,发上来我看看?
                  • Z
                    @veye_xumm dmesg.txt
                      @zjutony 我们的kernel并未生效。
                      请上传一下/boot/extlinux/extlinux.conf
                      • Z
                        @veye_xumm extlinux.txt
                          @zjutony
                          你好,我这边测试了一遍,没有问题。
                          跟你核对一下md5
                          ~$ md5sum /boot/Image
                          • Z
                              @zjutony
                              我刚才尝试了一下,用
                              你也可以这样尝试一下。
                              • Z
                                这个直接烧写是说的不用sdkmanager吗?
                                • Z
                                    @zjutony 用sdkmanager也是可以的。
                                      • Z
                                          @zjutony
                                          • Z
                                            我们是nx的板子,您看看这样子是不是操作正确的
