    Camera sync mode
    31 Posts 2 Posters 26.9k Views 1 Watching
    • G Offline
      g-towboat
      I have an CS-FPD-XAVIER-nCAM-IMX307 with 8 camera system - it works perfect!
      Now I want install the sync mode. In your manual its described as:
      SYNC signal connection:
      The synchronization signal is connected as shown in the figure above. J5 needs to be connected with J7's 2, 4, 6 and 8pin, and J6 is connected with J8's 2, 4, 6 and 8pin.
      For the schematic diagram of the SYNC signal, please refer to:
      ·          FPD-LINK3-2RX Datasheet
      ·          ADP-N2 Datasheet
      ·          ADP-N3 Datasheet
      But i dont know exactly what to do.
      Can you describe it an in other way. Or do you have an photo of the wiring on the APD-N3 Board?
        veye_xumm @g-towboat
        @g-towboat
        Accroding to the version log,http://wiki.veye.cc/index.php/CS-MIPI-IMX307_version_log,
        CS-MIPI-IMX307_FV2.33_LV3.3_20201106.bin
        Optimize the sync mechanism by using only frame synchronization signals.
        Fpdlink mode synchronization is supported.
        So the J5 to J8 connection is not necessary anymore. You just need to connect J6 and J8 together, as shown below.
        Please notice the pin1、3、5、7 of J6 and J8 are connected together separately, please use them flexibly.
        http://wiki.veye.cc/index.php/ADP-N3_Data_Sheet_index
        • G Offline
          g-towboat @veye_xumm
          Thanks for your answer.
          Did I understand that correctly. The connections should look like this:
          One wire from - to
          J6 pin 2 - J8 pin 2
          J6 pin 2 - J8 pin 2
          J6 pin 4 - J8 pin 4
          J6 pin 6 - J8 pin 6
            @g-towboat
            One wire from - to
            J6 pin 2 - J8 pin 2
            J6 pin 4 - J8 pin 4
            J6 pin 6 - J8 pin 6
            I think you just need to connect 2 4 6 8 pins of J6 and J8 together.
            And all 1 2 3 4 5 6 7 8 pins of J6 and J8 together will work too.
            • G Offline
              i'm sorry, but i still haven't got it. Can you describe it in a table e.g.:
              J6 Pin X - J8 Pin Y
              Thank you
                @g-towboat
                It's not some pairs of connection. It's a group of connection.
                For example:
                J6-2 is the source of XVS, and J6-4 J6-6 J6-8 J8-2 J8-4 J8-6 J8-8 are all sink of XVS.
                So what you need to do is connect all these pins together.
                J6-1 J6-3 J6-5 J6-7 are already connected together on the board.
                J8-1 J8-3 J8-5 J8-7 are already connected together on the board.
                You can use them if you want.
                • G Offline
                  • G Offline
                    e.g my post here:
                    http://forum.veye.cc/topic/21/camera-i2c-configuaration-for-sync-mode
                    I just have blue images like the post here:
                    http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode
                    But i have 8 cameras connected.
                    Do I also connect the boards: FPD-LINK3-2RX?
                    or is it the i2c configuration?
                    veye_xummV 2 Replies Last reply Reply Quote 1
                      @g-towboat
                      Since you use CS-FPD-XAVIER-nCAM-IMX307, FPD-LINK3-2RX is a part of this module.
                        @g-towboat
                        You can post your hardware connection here, I'll check it for you.
                        • G Offline
                          g-towboat
                          I think it's worked now, i have made an Firmware update of each camera. What is the best way to check synchronization?
                            @g-towboat
                            Please refer to:
                            http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                            • G Offline
                              @veye_xumm I still have blue Images.
                              Wire configuration standard.
                              Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                              Can you please check what i am doing wrong or post a detailed photo of the right configuration.
                              Thank you
                                @g-towboat
                                I think you pick out the wrong wire.
                                • G Offline
                                  SYNC signal connect:
                                  J7-3 (GPIO0) to J1-3 (GPIO0),
                                  J7-2 (GND) to J1-2 (GND)
                                  Any other wiring to do?
                                    everyone
                                    no
                                    • G Offline
                                      Any other ideas whats wrong ?
                                        @g-towboat
                                        • G Offline
                                          @veye_xumm Hi Xumm,
                                          #!/bin/bash
                                          SYNC_INIT="sync_init"
                                          STREAM_MODE="streammode"
                                          echo -e "connected cameras:"
                                          ls -l /dev/video*
                                          This is the result:
                                          connected cameras:
                                          w stream mode master
                                          w stream mode slave
                                          w stream mode slave
                                          w stream mode slave
                                          w stream mode slave
                                          w stream mode slave
                                          w stream mode slave
                                          w stream mode slave
                                          Looks good for me.
                                          Camera 0_1
                                          Camera 0_2
                                          Camera 1_1
                                          Camera 1_2
                                          Camera 2_1
                                          Camera 2_2
                                          Camera 3_1
                                          Camera 3_2
                                          #!/bin/bash
                                          cameras=7
                                          counter=0
                                          do
                                          	echo -e "Camera_"$counter
                                          	((counter++))
                                          done
                                          Camera 1 images looks good.
                                            @g-towboat
