    Camera sync mode
    31 Posts 2 Posters 25.7k Views 1 Watching
    • G Offline
      g-towboat
      I think it's worked now, i have made an Firmware update of each camera. What is the best way to check synchronization?
        veye_xumm @g-towboat
        @g-towboat
        Please refer to:
        http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
        • G Offline
          g-towboat @veye_xumm
          @veye_xumm I still have blue Images.
          Wire configuration standard.
          Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
          Can you please check what i am doing wrong or post a detailed photo of the right configuration.
          Thank you
            @g-towboat
            I think you pick out the wrong wire.
            • G Offline
              SYNC signal connect:
              J7-3 (GPIO0) to J1-3 (GPIO0),
              J7-2 (GND) to J1-2 (GND)
              Any other wiring to do?
                everyone
                no
                • G Offline
                  Any other ideas whats wrong ?
                    @g-towboat
                    • G Offline
                      @veye_xumm Hi Xumm,
                      #!/bin/bash
                      SYNC_INIT="sync_init"
                      STREAM_MODE="streammode"
                      echo -e "connected cameras:"
                      ls -l /dev/video*
                      This is the result:
                      connected cameras:
                      w stream mode master
                      w stream mode slave
                      w stream mode slave
                      w stream mode slave
                      w stream mode slave
                      w stream mode slave
                      w stream mode slave
                      w stream mode slave
                      Looks good for me.
                      Camera 0_1
                      Camera 0_2
                      Camera 1_1
                      Camera 1_2
                      Camera 2_1
                      Camera 2_2
                      Camera 3_1
                      Camera 3_2
                      #!/bin/bash
                      cameras=7
                      counter=0
                      do
                      	echo -e "Camera_"$counter
                      	((counter++))
                      done
                      Camera 1 images looks good.
                        @g-towboat
                        • G Offline
                          Hi here is my drawing:
                          Red: the jumpers
                          Camera 1 /dev/video0 image ok
                          Camera 4 /dev/video3 image ok
                            @g-towboat
                            • G Offline
                              Here is an image
                                @g-towboat
                                • G Offline
                                    @g-towboat
                                    • G Offline
                                      • G Offline
                                        veye_xummV 1 Reply Last reply Reply Quote 1
                                          @g-towboat
                                          It works fine here.
                                          Sorry again.
                                          • G Offline
