    Camera sync mode
    31 Posts 2 Posters 26.1k Views 1 Watching
      veye_xumm @g-towboat
      SYNC signal connect:
      J7-3 (GPIO0) to J1-3 (GPIO0),
      J7-2 (GND) to J1-2 (GND)
      everyone
      Any other wiring to do?
      no
      • G Offline
        g-towboat @veye_xumm
        Any other ideas whats wrong ?
          @g-towboat
          • G Offline
            @veye_xumm Hi Xumm,
            #!/bin/bash
            SYNC_INIT="sync_init"
            STREAM_MODE="streammode"
            echo -e "connected cameras:"
            ls -l /dev/video*
            This is the result:
            connected cameras:
            w stream mode master
            w stream mode slave
            w stream mode slave
            w stream mode slave
            w stream mode slave
            w stream mode slave
            w stream mode slave
            w stream mode slave
            Looks good for me.
            Camera 0_1
            Camera 0_2
            Camera 1_1
            Camera 1_2
            Camera 2_1
            Camera 2_2
            Camera 3_1
            Camera 3_2
            #!/bin/bash
            cameras=7
            counter=0
            do
            	echo -e "Camera_"$counter
            	((counter++))
            done
            Camera 1 images looks good.
              @g-towboat
              • G Offline
                Hi here is my drawing:
                Red: the jumpers
                Camera 1 /dev/video0 image ok
                Camera 4 /dev/video3 image ok
                  @g-towboat
                  • G Offline
                    Here is an image
                      @g-towboat
                      • G Offline
                          @g-towboat
                          • G Offline
                            • G Offline
                              veye_xummV 1 Reply Last reply Reply Quote 1
                                @g-towboat
                                It works fine here.
                                Sorry again.
                                • G Offline
                                    @g-towboat
                                    It is really nice.
                                    ./fpdlink3_i2c_jetson.sh -f sync_init .....
                                    This cmd need to set after each reboot.
                                    ./cs_mipi_i2c.sh -w -f streammode
                                    The camera can save streammode.
