    Camera sync mode
    31 Posts 2 Posters 26.8k Views 1 Watching
    • G Offline
      g-towboat @veye_xumm
      • G Offline
        e.g my post here:
        http://forum.veye.cc/topic/21/camera-i2c-configuaration-for-sync-mode
        I just have blue images like the post here:
        http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode
        But i have 8 cameras connected.
        Do I also connect the boards: FPD-LINK3-2RX?
        or is it the i2c configuration?
        veye_xummV 2 Replies Last reply Reply Quote 1
          veye_xumm @g-towboat
          @g-towboat
          Since you use CS-FPD-XAVIER-nCAM-IMX307, FPD-LINK3-2RX is a part of this module.
            @g-towboat
            You can post your hardware connection here, I'll check it for you.
            • G Offline
              g-towboat
              I think it's worked now, i have made an Firmware update of each camera. What is the best way to check synchronization?
                @g-towboat
                Please refer to:
                http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                • G Offline
                  @veye_xumm I still have blue Images.
                  Wire configuration standard.
                  Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                  Can you please check what i am doing wrong or post a detailed photo of the right configuration.
                  Thank you
                    @g-towboat
                    I think you pick out the wrong wire.
                    • G Offline
                      SYNC signal connect:
                      J7-3 (GPIO0) to J1-3 (GPIO0),
                      J7-2 (GND) to J1-2 (GND)
                      Any other wiring to do?
                        everyone
                        no
                        • G Offline
                          Any other ideas whats wrong ?
                            @g-towboat
                            • G Offline
                              @veye_xumm Hi Xumm,
                              #!/bin/bash
                              SYNC_INIT="sync_init"
                              STREAM_MODE="streammode"
                              echo -e "connected cameras:"
                              ls -l /dev/video*
                              This is the result:
                              connected cameras:
                              w stream mode master
                              w stream mode slave
                              w stream mode slave
                              w stream mode slave
                              w stream mode slave
                              w stream mode slave
                              w stream mode slave
                              w stream mode slave
                              Looks good for me.
                              Camera 0_1
                              Camera 0_2
                              Camera 1_1
                              Camera 1_2
                              Camera 2_1
                              Camera 2_2
                              Camera 3_1
                              Camera 3_2
                              #!/bin/bash
                              cameras=7
                              counter=0
                              do
                              	echo -e "Camera_"$counter
                              	((counter++))
                              done
                              Camera 1 images looks good.
                                @g-towboat
                                • G Offline
                                  Hi here is my drawing:
                                  Red: the jumpers
                                  Camera 1 /dev/video0 image ok
                                  Camera 4 /dev/video3 image ok
                                    @g-towboat
                                    • G Offline
                                      Here is an image
                                        @g-towboat
                                        • G Offline
                                            @g-towboat
