    Camera sync mode
    31 Posts 2 Posters 26.1k Views 1 Watching
      veye_xumm @g-towboat
      @g-towboat
      Accroding to the version log,http://wiki.veye.cc/index.php/CS-MIPI-IMX307_version_log,
      CS-MIPI-IMX307_FV2.33_LV3.3_20201106.bin
      Optimize the sync mechanism by using only frame synchronization signals.
      Fpdlink mode synchronization is supported.
      So the J5 to J8 connection is not necessary anymore. You just need to connect J6 and J8 together, as shown below.
      Please notice the pin1、3、5、7 of J6 and J8 are connected together separately, please use them flexibly.
      http://wiki.veye.cc/index.php/ADP-N3_Data_Sheet_index
      • G Offline
        g-towboat @veye_xumm
        Thanks for your answer.
        Did I understand that correctly. The connections should look like this:
        One wire from - to
        J6 pin 2 - J8 pin 2
        J6 pin 2 - J8 pin 2
        J6 pin 4 - J8 pin 4
        J6 pin 6 - J8 pin 6
          @g-towboat
          One wire from - to
          J6 pin 2 - J8 pin 2
          J6 pin 4 - J8 pin 4
          J6 pin 6 - J8 pin 6
          I think you just need to connect 2 4 6 8 pins of J6 and J8 together.
          And all 1 2 3 4 5 6 7 8 pins of J6 and J8 together will work too.
          • G Offline
            i'm sorry, but i still haven't got it. Can you describe it in a table e.g.:
            J6 Pin X - J8 Pin Y
            Thank you
              @g-towboat
              It's not some pairs of connection. It's a group of connection.
              For example:
              J6-2 is the source of XVS, and J6-4 J6-6 J6-8 J8-2 J8-4 J8-6 J8-8 are all sink of XVS.
              So what you need to do is connect all these pins together.
              J6-1 J6-3 J6-5 J6-7 are already connected together on the board.
              J8-1 J8-3 J8-5 J8-7 are already connected together on the board.
              You can use them if you want.
              • G Offline
                • G Offline
                  e.g my post here:
                  http://forum.veye.cc/topic/21/camera-i2c-configuaration-for-sync-mode
                  I just have blue images like the post here:
                  http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode
                  But i have 8 cameras connected.
                  Do I also connect the boards: FPD-LINK3-2RX?
                  or is it the i2c configuration?
                  veye_xummV 2 Replies Last reply Reply Quote 1
                    @g-towboat
                    Since you use CS-FPD-XAVIER-nCAM-IMX307, FPD-LINK3-2RX is a part of this module.
                      @g-towboat
                      You can post your hardware connection here, I'll check it for you.
                      • G Offline
                        g-towboat
                        I think it's worked now, i have made an Firmware update of each camera. What is the best way to check synchronization?
                          @g-towboat
                          Please refer to:
                          http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                          • G Offline
                            @veye_xumm I still have blue Images.
                            Wire configuration standard.
                            Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                            Can you please check what i am doing wrong or post a detailed photo of the right configuration.
                            Thank you
                              @g-towboat
                              I think you pick out the wrong wire.
                              • G Offline
                                SYNC signal connect:
                                J7-3 (GPIO0) to J1-3 (GPIO0),
                                J7-2 (GND) to J1-2 (GND)
                                Any other wiring to do?
                                  everyone
                                  no
                                  • G Offline
                                    Any other ideas whats wrong ?
                                      @g-towboat
                                      • G Offline
                                        @veye_xumm Hi Xumm,
                                        #!/bin/bash
                                        SYNC_INIT="sync_init"
                                        STREAM_MODE="streammode"
                                        echo -e "connected cameras:"
                                        ls -l /dev/video*
                                        This is the result:
                                        connected cameras:
                                        w stream mode master
                                        w stream mode slave
                                        w stream mode slave
                                        w stream mode slave
                                        w stream mode slave
                                        w stream mode slave
                                        w stream mode slave
                                        w stream mode slave
                                        Looks good for me.
                                        Camera 0_1
                                        Camera 0_2
                                        Camera 1_1
                                        Camera 1_2
                                        Camera 2_1
                                        Camera 2_2
                                        Camera 3_1
                                        Camera 3_2
                                        #!/bin/bash
                                        cameras=7
                                        counter=0
                                        do
                                        	echo -e "Camera_"$counter
                                        	((counter++))
                                        done
                                        Camera 1 images looks good.
                                          @g-towboat
                                          • G Offline
                                            Hi here is my drawing:
                                            Red: the jumpers
                                            Camera 1 /dev/video0 image ok
                                            Camera 4 /dev/video3 image ok
