    Camera sync mode
    31 Posts 2 Posters 26.8k Views 1 Watching
    • G Offline
      g-towboat @veye_xumm
      e.g my post here:
      http://forum.veye.cc/topic/21/camera-i2c-configuaration-for-sync-mode
      I just have blue images like the post here:
      http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode
      But i have 8 cameras connected.
      Do I also connect the boards: FPD-LINK3-2RX?
      or is it the i2c configuration?
      veye_xummV 2 Replies Last reply Reply Quote 1
        veye_xumm @g-towboat
        @g-towboat
        Since you use CS-FPD-XAVIER-nCAM-IMX307, FPD-LINK3-2RX is a part of this module.
          @g-towboat
          You can post your hardware connection here, I'll check it for you.
          • G Offline
            g-towboat
            I think it's worked now, i have made an Firmware update of each camera. What is the best way to check synchronization?
              @g-towboat
              Please refer to:
              http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
              • G Offline
                @veye_xumm I still have blue Images.
                Wire configuration standard.
                Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
                Can you please check what i am doing wrong or post a detailed photo of the right configuration.
                Thank you
                  @g-towboat
                  I think you pick out the wrong wire.
                  • G Offline
                    SYNC signal connect:
                    J7-3 (GPIO0) to J1-3 (GPIO0),
                    J7-2 (GND) to J1-2 (GND)
                    Any other wiring to do?
                      everyone
                      no
                      • G Offline
                        Any other ideas whats wrong ?
                          @g-towboat
                          • G Offline
                            @veye_xumm Hi Xumm,
                            #!/bin/bash
                            SYNC_INIT="sync_init"
                            STREAM_MODE="streammode"
                            echo -e "connected cameras:"
                            ls -l /dev/video*
                            This is the result:
                            connected cameras:
                            w stream mode master
                            w stream mode slave
                            w stream mode slave
                            w stream mode slave
                            w stream mode slave
                            w stream mode slave
                            w stream mode slave
                            w stream mode slave
                            Looks good for me.
                            Camera 0_1
                            Camera 0_2
                            Camera 1_1
                            Camera 1_2
                            Camera 2_1
                            Camera 2_2
                            Camera 3_1
                            Camera 3_2
                            #!/bin/bash
                            cameras=7
                            counter=0
                            do
                            	echo -e "Camera_"$counter
                            	((counter++))
                            done
                            Camera 1 images looks good.
                              @g-towboat
                              • G Offline
                                Hi here is my drawing:
                                Red: the jumpers
                                Camera 1 /dev/video0 image ok
                                Camera 4 /dev/video3 image ok
                                  @g-towboat
                                  • G Offline
                                    Here is an image
                                      @g-towboat
                                      • G Offline
                                          @g-towboat
                                          • G Offline
