    Camera sync mode
    31 Posts 2 Posters 26.8k Views 1 Watching
    • G Offline
      g-towboat @veye_xumm
      Any other ideas whats wrong ?
        veye_xumm @g-towboat
        @g-towboat
        • G Offline
          @veye_xumm Hi Xumm,
          #!/bin/bash
          SYNC_INIT="sync_init"
          STREAM_MODE="streammode"
          echo -e "connected cameras:"
          ls -l /dev/video*
          This is the result:
          connected cameras:
          w stream mode master
          w stream mode slave
          w stream mode slave
          w stream mode slave
          w stream mode slave
          w stream mode slave
          w stream mode slave
          w stream mode slave
          Looks good for me.
          Camera 0_1
          Camera 0_2
          Camera 1_1
          Camera 1_2
          Camera 2_1
          Camera 2_2
          Camera 3_1
          Camera 3_2
          #!/bin/bash
          cameras=7
          counter=0
          do
          	echo -e "Camera_"$counter
          	((counter++))
          done
          Camera 1 images looks good.
            @g-towboat
            • G Offline
              Hi here is my drawing:
              Red: the jumpers
              Camera 1 /dev/video0 image ok
              Camera 4 /dev/video3 image ok
                @g-towboat
                • G Offline
                  Here is an image
                    @g-towboat
                    • G Offline
                        @g-towboat
                        • G Offline
                          • G Offline
                            veye_xummV 1 Reply Last reply Reply Quote 1
                              @g-towboat
                              It works fine here.
                              Sorry again.
                              • G Offline
                                  @g-towboat
                                  It is really nice.
                                  ./fpdlink3_i2c_jetson.sh -f sync_init .....
                                  This cmd need to set after each reboot.
                                  ./cs_mipi_i2c.sh -w -f streammode
                                  The camera can save streammode.
