    Camera sync mode
    31 Posts 2 Posters 25.4k Views 1 Watching
    • G Offline
      g-towboat @veye_xumm
      SYNC signal connect:
      J7-3 (GPIO0) to J1-3 (GPIO0),
      J7-2 (GND) to J1-2 (GND)
      Any other wiring to do?
        veye_xumm @g-towboat
        everyone
        no
        • G Offline
          Any other ideas whats wrong ?
            @g-towboat
            • G Offline
              @veye_xumm Hi Xumm,
              #!/bin/bash
              SYNC_INIT="sync_init"
              STREAM_MODE="streammode"
              echo -e "connected cameras:"
              ls -l /dev/video*
              This is the result:
              connected cameras:
              w stream mode master
              w stream mode slave
              w stream mode slave
              w stream mode slave
              w stream mode slave
              w stream mode slave
              w stream mode slave
              w stream mode slave
              Looks good for me.
              Camera 0_1
              Camera 0_2
              Camera 1_1
              Camera 1_2
              Camera 2_1
              Camera 2_2
              Camera 3_1
              Camera 3_2
              #!/bin/bash
              cameras=7
              counter=0
              do
              	echo -e "Camera_"$counter
              	((counter++))
              done
              Camera 1 images looks good.
                @g-towboat
                • G Offline
                  Hi here is my drawing:
                  Red: the jumpers
                  Camera 1 /dev/video0 image ok
                  Camera 4 /dev/video3 image ok
                    @g-towboat
                    • G Offline
                      Here is an image
                        @g-towboat
                        • G Offline
                            @g-towboat
                            • G Offline
                              • G Offline
                                veye_xummV 1 Reply Last reply Reply Quote 1
                                  @g-towboat
                                  It works fine here.
                                  Sorry again.
                                  • G Offline
                                      @g-towboat
                                      It is really nice.
                                      ./fpdlink3_i2c_jetson.sh -f sync_init .....
                                      This cmd need to set after each reboot.
                                      ./cs_mipi_i2c.sh -w -f streammode
                                      The camera can save streammode.
