• 在orin nano 8G上尝试使用cssc132失败
    35
    12k Views
    @robot 有这个可能,我们很久前有一个CS-MIPI-IMX307,在某些板子上有类似的问题。
  • MV-MIPI-IMX287M最大帧率是多少?
    @lpcq2000 不客气。
  • 0 Votes
    6k Views
    @sheko Sorry, I just got back from the Chinese New Year holiday. Regarding using the RAW-MIPI-SC132M on the Raspberry Pi 5, I suggest you primarily refer to this document. It covers driver installation, how to use the V4L2 mode, and methods for previewing using OpenCV. https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi
  • 0 Votes
    S
    @veye_xumm That's right. It worked with the lens. Thank you very much for your technical support.
  • rk3588 camera RAW 显示不正常
    5k Views
    @fumyang 请问您用的是哪个相机模组?
  • sc130在214fps下抓拍不到闪光源
    15
    10k Views
    X
    @veye_xumm 是的 非阻塞缓存后写图,已经解决了。抓拍的图像基本模拟一次就有一张抓拍,因为闪一次时间是1ms 所以只抓到一张也是合理的。
  • This topic is deleted!
  • cssc132 driver for Raspberry pi 5
    @reinbb OK
  • CS-MIPI-IMX307 Serdes适配求助
    7
    5k Views
    F
    @veye_xumm 感谢感谢
  • ADP-N1-V2.0板载咨询
    4k Views
    F
    @veye_xumm 感谢感谢,谢谢楼主指点
  • CS-MIPI-IMX307 hardware trigger
    @lnlinh said in CS-MIPI-IMX307 hardware trigger: streammode Sorry, CS-MIPI-IMX307 does not support external trigger mode, only free running and sync mode.
  • RAW-MIPI-SC132M驱动编译后无法正常播放
    12
    6k Views
    客户已解决。是kernel配置中关于rkcif的配置原因。
  • CSSC132 driver load 问题
    9
    6k Views
    H
    @veye_xumm 对的,所以我感觉很奇怪。 下面是我修改的install_driver.sh echo "Add cma=128M to /boot/firmware/cmdline.txt " echo "--------------------------------------" sudo sed 's/cma=128M//g' -i /boot/firmware/cmdline.txt sudo sed 's/[[:blank:]]*$//' -i /boot/firmware/cmdline.txt sudo sed 's/$/& cma=128M/g' -i /boot/firmware/cmdline.txt echo "Installing the $driver_name.ko driver" echo "--------------------------------------" sudo install -p -m 644 ./driver_bin/$(uname -r)/$driver_name.ko /lib/modules/$(uname -r)/kernel/drivers/media/i2c/ sudo install -p -m 644 ./driver_bin/$(uname -r)/$driver_name.dtbo /boot/firmware/overlays/ sudo /sbin/depmod -a $(uname -r) echo "reboot now?(y/n):" 谢谢!
  • No output from IMX462 module
    @frankerooney Since the driver has been probed, I assume that the hardware connection is fine. @frankerooney said in No output from IMX462 module: The program just then sits there, producing no output to stdout. I've waited 20 minutes or so, nothing produced. For v4l2 mode, veye_raspivid cannot be used . Please try part7——use qv4l2 first.
  • v4l2函数获取曝光值,为什么不行
    12
    8k Views
    @lin 参考一下part7.3
  • IMX335 trigger synchronization
    @hchorsi said in IMX335 trigger synchronization: Can the IMX335 sensor be synchronized with an illumination source such as projector using trigger pins? What are the requirements for the trigger signal in terms of the frequency, amplitude, duty cycle,...? Sorry, the VEYE-MIPI-IMX335 has an ISP module and does not support external synchronization and trigger signals.
  • software trigger for MV-MIPI-SC130M
    4k Views
    @dm @dm said in software trigger for MV-MIPI-SC130M: Are the trigger pins of the sensor not connected to the device controller? The trigger pins of the sensor are connected to the device controller
  • 相机驱动显示正常,但是不能连接到dphy上
    @lin 不好意思,现在我们研发的状态是RK3568平台的驱动移植还没有完成。 此事我们已经列入开发计划,预计春节后开始。
  • cs-mipi-imx307检测不到摄像头
    16
    9k Views
    @liuyue 已私信。
  • v4l2显示摄像头可调参数语句用不了
    4k Views
    L
    @veye_xumm 谢谢,原来它只能写成/dev/v4l-subdev2
