• jetpack4.5 use sc132
    @npcdna Has the problem been solved?
  • CS-MIPI-IMX307
    Moved
    @alisa 不能。 我们这个模组除了有sony的sensor还有isp功能。
  • CS-MIPI-307 new framerate
    Moved
    1k Views
    Hi, I think this is a bug of cs_mipi_i2c.sh , I have fixed it and update to github. please check with the new script. By the way,please refer to this page for slow shutter: http://wiki.veye.cc/index.php/CS_Camera_Slow_Shutter_manual Regards!
  • It went into a boot loop. [JP 4.4.1, Nano B01, IMX307]
    O
    @veye_xumm Thank you for your answer.
  • I2C command for SC132
    @cvuser said in I2C command for SC132: Thank you. I will test it. Have you solved your problem?
