• 请问下imx307如何修改分辨率输出为720*720呢
    7
    @jdx-jdx 这样,请给我们邮件联系一下 xumm@csoneplus.com
  • IMX307相机两路同时显示只显示一路
    @jdx-jdx 不好意思,这几天比较忙,一直没有时间去查原因。 这个并列显示本身是从nVidia网上找到的一个纯做演示的demo。其实并无太大的实用价值。 原来的时候是v4l2src的,后来由于英伟达官方建议用nvv4l2camerasrc,所以我们的wiki也改了。 但是看你的截图还是v4l2src的。 请参考我们wiki上的命令行用一下新的指令测试。 期待你的结果。
  • cs_mipi_i2c.sh无效
    @aimerdesu 好的,谢谢!
  • VEYE CS Camera on MYIR i.MX8M Mini board
    @alper-gur Hi, I think we have discussed this issue again by email.
  • sc-mipi-sc132取像失败
    1k Views
    @kunx 你好,请参考: http://wiki.veye.cc/index.php/CS-MIPI-X_for_Raspberry_Pi/zh part2
  • This topic is deleted!
    No one has replied
  • 0 Votes
    @ess How did you determine that it was not effective after performing the following operation? ./cs_mipi_i2c.sh -w -f videofmt -p1 1080 -p2 1280 -p3 45 -b 8 Did you try reading the parameters back? ./cs_mipi_i2c.sh -r -f videofmt -b 8 Please try this operation above. When you try to get the image, the driver will be called and the driver will modify the working resolution of the camera according to the parameters passed down from the application layer, so you need to configure the resolution when you get the image. For example: gst-launch-1.0 nvv4l2camerasrc ! "video/x-raw(memory:NVMM),format=(string)UYVY, width=(int)1280, height=(int)1080, framerate=(fraction)45/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
  • CS-MIPI-SC132重置(sysreset)后无法取图
    1k Views
    No one has replied
  • CS-MIPI-SC132双相机配置
    19
    8k Views
    J
    全部重来以后正常了,估计是旧版的配置GPIO的问题
  • sc132 sync模式无电平输出
    8
    @zjutony [image: 1640853785751-a5a4e9a6-73d9-4791-be79-2b8d3929796d-image.png] [image: 1640853797021-c8d0ee25-5791-4830-baae-bb3c47232379-image.png] 你好,我这边freerunning模式跑的,测试没问题。 要不你配置一下sysreset,让模组恢复下默认值,然后再测试试试?
  • CSSC132外部触发模式bug
    10
    4k Views
    @zjutony 你指的英伟达平台帧率过低的情况下的问题吗? 这个跟采用什么模式触发没有关系。 是英伟达的driver的问题。
  • CS132 Mipi csi global shutter camera not working on jetson Nano
    12
    4k Views
    @jetsonnano What a bummer, they should have open the code. We have customers who use avermedia and avermedia helped with the driver porting work. They probably do it for volume customers only! If you have the ability, you can try to decompile avermedia's dtb file, get the dts and then modify it into our module. But it will be more troublesome.
  • cs-mipi-imx307如何配置输出数据格式
    @rice 您好,不好意思,现在这个模组不支持raw数据输出。
  • CS-MIPI-IMX307 I2C通信失败
    12
    5k Views
    @rice 通信时钟100k和400k都可以。 一般的fpga的3.3VCCIO, VIHmin<2.88V,电平应该不是识别不了的原因。 确认下IO上拉电阻大小。1.5K~4.7K最佳。 确认下访问地址的理解是否有出入。 [image: 1638498130140-68b1503b-cb13-4c88-85f4-149004cb6eef-e194d314de6f636c1200b5f216e227d.png] [image: 1638498146282-e936a931-289f-4aa4-aa31-997c3ba1c25a-0a00d8eb575881a763313dd68213c7a.png]
  • CSI132相机nvidia nx平台上无法更新硬件
    28
    18k Views
    @zjutony 不客气
  • cs132和FPGA间的MIPI适配问题
    @harryxiong 你好,不好意思没有说清楚怎样停止csi输出。 我们模组的0x03寄存器,写1则表示使能csi输出,写0则表示停止输出。 建议你的操作是,重启或者reset模组之前,将这个地址写为0。 模组重启完成后,会自动恢复的。
  • tx2 jetpack4.5.1
    14
    8k Views
    @npcdna 这个问题提出已经很久了,一直没有更新状态。 我会将状态标记为解决,如果需要,可以再次跟帖,或者直接打开问题。
  • GStreamer读取SC132的图像时,当相机运动时会报错
    @cvuser 这个问题提出已经很久了,一直没有更新状态。 我会将状态标记为解决,如果需要,可以再次跟帖,或者直接打开问题。
  • CS-MIPI-IMX307 安裝問題
    7
    @r-l 这个问题提出已经很久了,一直没有更新状态。 我会将状态标记为解决,如果需要,可以再次跟帖,或者直接打开问题。
  • Xavier NX does not reboot after changing Image
    7
    @imagidan This question has been asked for a long time and the status has not been updated. I will mark the status as solved, so you can follow up again if needed, or just open the question.
