• 瑞泰Jetson NX CS-MIPI-SC132 dtb安装
    S
    @veye_xumm 好的,我向瑞泰那边反馈一下。
  • IMX307 i2c如何调整图像锐度与降噪?
    @luchec 你好,你用的车牌识别相机是多少分辨率的? 我们的307用的镜头是什么型号? 我的感觉还是先考虑分辨率,视场角度的问题,而不是考虑降噪锐度等参数。
  • This topic is deleted!
    No one has replied
  • 关于低分辨率高FPS下的成像中心问题
    1k Views
    @fire 你好,这是一个较早版本的bug。请升级固件即可解决。 http://wiki.veye.cc/index.php/CS-MIPI-IMX307_version_log/zh http://wiki.veye.cc/index.php/USB升级固件方法
  • 0 Votes
    @james 是的,不客气。
  • SC132 documentation
    1k Views
    @fiepfiep @fiepfiep said in SC132 documentation: Where do I find schematics and firmware source code for sc132? Sorry, they are not open source. @fiepfiep said in SC132 documentation: What is the goal of the onboard microcontroller? ISP(AE.. etc) and other control things. @fiepfiep said in SC132 documentation: Is it possible to have direct register access to the sensor? http://wiki.veye.cc/index.php/CS-MIPI-X_i2c#sreg via sreg cmd, you can read sensor register.
  • Problem cross-compiling
    T
    @veye_xumm Thanks for the offer. While posting the Makefile I noticed I had -overlay.dtbo in the filenames. Compiling now.
  • 树莓派CM4使用SC132时,无法使用i2c command
    1k Views
    @cvuser 你好,我在官方的CMIO板子上是正常的。请帮忙执行以下下面的脚本发给我一下结果: rev=`cat /proc/cpuinfo | grep Revision | awk '{print substr($NF,length($NF)-5,6)}'` echo $rev
  • 树莓派CM4使用双SC132时Video1无法捕获
    C
    Yes!! it works!
  • 0 Votes
    @mk Image brightness depends on several factors: lens, sensor sensitivity, exposure time, gain, and post-processing. The photosensitive ability of lens and sensor is constant in the set state, and the post-processing is ugly because it will damage the details of the image. In AE mode, adjusting aetarget will automatically adjust the exposure time and gain to achieve the purpose of adjusting the brightness of the image. In ME mode, the exposure time and gain need to be adjusted manually. Because you want to control it manually, there is no auto adjust and no target.
  • cs_imx307_board_setup: invalid sensor model id
    jetson xaviernx csmipi imx307
    @lubertroft You solved the problem by yourself. It was great!
  • FPS change at midnight?
    @tj OK. If there is any new situation, please communicate with me again.
  • Error installing driver V4L2 on raspberry pi
    4k Views
    M
    @veye_xumm Problem solved, this topic can be closed. Thx!
  • Get high framerate V4L2 in python/opencv?
    9
    5k Views
    @tj You are welcome.
  • 关于imx307相机延时的优化
    Z
    @veye_xumm 好的谢谢
  • CSSC132除了uyvy格式,是否还支持其他格式
    R
    @veye_xumm 好的
  • imx307相机驱动框架修改
    7
    Z
    @veye_xumm 好的,感谢
    No one has replied
  • CSSC132如何外接补光灯
    @robot said in CSSC132如何外接补光灯: 我可以断开这个排线将这引脚直接接入我的补光灯吗? 可以。 @robot said in CSSC132如何外接补光灯: 请问我想要添加一个亮度由摄像头控制的补光灯,需要如何设计,您是否有产品或参考设计可以提供 不好意思,现在没有这个功能。 请问亮度由摄像头控制的话,控制逻辑是什么呢? 控制协议呢?
  • CS-MIPI_IMX307 best settings to capture stars?
    Moved
    9
    6k Views
    M
    Why not use Again 27,and Dgain 5? Thanks I will try and let you know.
