    2. CS MIPI camera
    Log in to post
    Load new posts
    • Recently Replied
    • Recently Created
    • Most Posts
    • Most Views
    • M
      mipi-sc132 相机无法显示图像
      Watching Ignoring Scheduled Pinned Locked Moved
      @meitiever 这个问题提出已经很久了,一直没有更新状态。 我会将状态标记为解决,如果需要,可以再次跟帖,或者直接打开问题。
    • T
      CS-MIPI-IMX307 not working on XAVIER NX release 32.6.1
      @techies Sorry reply finished. China took a 7 day holiday. We just got back to work. There is no tab in front of FDT. [image: 1633680627705-a2f5b3f9-c6ad-4b9e-9231-6477eebfc957-image.png] [image: 1633680825135-039e00d7-794d-4732-825b-1a594420362d-image.png]
    • M
      CS-MIPI-IMX307 camera Gstreamer UDP streaming error!
      @maponarooo You are welcome.
    • J
      使用IMX307相机dtb和Image在agx xavier更新dtb失败
      9
      @jdx-jdx 是的。probe成功才会生成video节点。
    • M
      Possible typo in CS-MIPI Wiki
      7
      @macdaddyfpv yes,this is a typo ,thanks!
    • E
      Problem installing the driver for the SC132.
      11
      5k Views
      @esjeeybi I have compiled the version you need, please check GitHub.
    • M
      IMX307 Decimal Framerate
      @macdaddyfpv You are welcome.
    • V
      IMX327-增强款无法在nx上使用
      9
      @vvxy 当然,327型号只支持1080p这个模式。 具体可以看我们wiki上的手册。
    • P
      IMX307 video bitrate not configurable
      No one has replied
    • 随
      AGX CS-MIPI-307 Opencv操作
      @veye_xumm 由于时间太久了,客户没有进一步的反馈,我会把这个帖子标记为已解决.
      How to use the software trigger of the CSSC132
      Watching Ignoring Scheduled Pinned Locked Moved cssc132 agx xavier software trigger
      @veye_xumm As the time is too long and there is no further feedback from the customer, I will mark this post as resolved.
    • F
      CS-MIPI-IMX307模组veye_raspipreview以及veye_raspivid屏幕上不输出图像
    • D
      Does not working exposure time for manual mode in the CS-MIPI-SC132
      9
    • T
      Getting raw, uncompressed images CS-MIPI-SC132
      1 Votes
      @teacup The camera contains a fully functional isp module. The output signal of sensor is indeed 10bit raw, but the YUV data output by the camera is not the result of simple mathematical operation of sensor data. I don't think it is suitable for making PTS curve.
    • J
      在Xavier-NX定制载板上使用sc132
      @jianping http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Gstreamer_Usage 可以先试试这个。其他的参考上面的这个链接。 gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)1080, framerate=(fraction)45/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
    • T
      安装了bsp、image这些软件会影响使用其他品牌的相机吗?
      @toosim 你好,直接根据英伟达的官方资料烧写官方版本即可。 https://developer.nvidia.com/embedded/learn/getting-started-jetson
    • N
      tx2 jetpack4.5
      @npcdna http://wiki.veye.cc/index.php/CS-MIPI-SC132_Data_Sheet/zh [image: 1625014914459-da0eefcb-5b35-42a0-90ed-eef9985b0124-image.png]
    • R
      CS-MIPI-SC132 got Internal data stream error on Xavier NX with Jetpack 5.1
      @ryanclark You took care of it yourself. that's great!
      Setting YUV-sequence CSSC132
      L
      Thank you, that solved the problem. It would be helpful if you could update that in point 3.45 on the site: http://wiki.veye.cc/index.php/CS-MIPI-X_i2c Regards
    • J
      CS- MIPI-SC132 在xavier NX 上适配
      1k Views
      @jianping http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2/zh http://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson/zh
