    40 Posts 2 Posters 28.3k Views 1 Watching
    • H Offline
      hello @hello
      @hello
      进行4.2.1视频预览测试没有出现预览:
      • H Offline
        hello @hello
        @hello
          veye_xumm @hello
          现在你的系统检测到了。
          • H Offline
            hello @veye_xumm
            • H Offline
              hello @hello
              @hello
              New clock: GstSystemClock
              Setting pipeline to READY ...
              Setting pipeline to NULL ...
              Freeing pipeline ...
              root@hello:/dev# dmesg
              [ 4.451868] CPU1: shutdown
              [ 4.509501] CPU2: shutdown
              [ 192.439657] Enabling wake24
              [ 192.445718] Enabling wake53
              [ 192.474213] Enabling wake83
              [ 192.474222] Enabling wake29
              [ 192.486471] Enabling wake76
              [ 192.486473] Enabling wake77
              [ 192.486475] Enabling wake78
              [ 192.486477] Enabling wake79
              [ 192.486479] Enabling wake80
              [ 192.486481] Enabling wake81
              [ 192.486483] Enabling wake82
              [ 192.486520] Enabling wake73
              [ 192.555437] Enabling wake71
              [ 192.587463] CPU3: shutdown
              [ 192.619451] CPU4: shutdown
              [ 192.647445] CPU5: shutdown
              [ 192.652403] Entered SC7
              [ 192.652403] Exited SC7
              [ 192.658275] CPU3 is up
              [ 192.664019] CPU4 is up
              [ 192.669812] CPU5 is up
              capture channel
              root@hello:/dev#
              • H Offline
                hello @hello
                @hello
                关于这个提供下下载的链接吧?
                下载来源如下:
                这个不是最新的吗?
                另外使用新的dtb做法是直接拷贝覆盖吧?可要烧写步骤呀?
                • H Offline
                  hello @hello
                  @hello
                  下载如下的dtb
                  烧写更新完成后发现摄像头sensor都检测不到了???
                    veye_xumm @hello
                    @hello
                    dmesg | grep veye
                    1. 请检测一下你的排线有没有插歪了的情况?
                    • H Offline
                      hello @veye_xumm
                        veye_xumm @hello
                          veye_xumm @hello
                          @hello 请问解决了吗?
                          • H Offline
                            hello @veye_xumm
                            @hello 请问解决了吗?
                            谢谢
                              veye_xumm @hello
                              • H Offline
                                hello @veye_xumm
                                刚试了很多次,不行,没效果
                                  veye_xumm @hello
                                  @hello
                                  你在终端杀掉gst-launch-1.0进程也是可以的
                                  • H Offline
                                    hello @veye_xumm
                                    @hello
                                    现在全屏都是预览的摄像头画面,退不出来,进不了终端
                                      veye_xumm @hello
                                      • H Offline
                                        hello @veye_xumm
                                        好的,感谢,需要的就是这个
                                        • H Offline
                                          hello @hello
                                          @hello
                                          已经通过建议方案2成功退出预览,问题解决,谢谢!
