    40 Posts 2 Posters 28.3k Views 1 Watching
    • H Offline
      hello @hello
      @hello
      • H Offline
        hello @hello
        @hello
        继续3.6.2步骤:
        完成文档3.6.2操作步骤
        接下来进行文档3.6.3升级Image和DTB步骤:
        3)进入Jetson开发板的系统,执行替换image操作
        4)进入Host PC上执行烧写DTS分区
        进入recovery模式执行文档说明中的烧写命令
        烧写成功如下:
        断电重启
        • H Offline
          hello @hello
          @hello
          继续文档3.7与3.8中的步骤操作:
          这些结果基本确认没问题吧?
          至此测试结果显示是否表面都OK呀?
            veye_xumm @hello
            @hello
            这里表面你检测到了一个camera
            • H Offline
              hello @veye_xumm
              • H Offline
                hello @hello
                @hello
                • H Offline
                  hello @hello
                  @hello
                  进行4.2.1视频预览测试没有出现预览:
                  • H Offline
                    hello @hello
                    @hello
                      veye_xumm @hello
                      现在你的系统检测到了。
                      • H Offline
                        hello @veye_xumm
                        • H Offline
                          hello @hello
                          @hello
                          New clock: GstSystemClock
                          Setting pipeline to READY ...
                          Setting pipeline to NULL ...
                          Freeing pipeline ...
                          root@hello:/dev# dmesg
                          [ 4.451868] CPU1: shutdown
                          [ 4.509501] CPU2: shutdown
                          [ 192.439657] Enabling wake24
                          [ 192.445718] Enabling wake53
                          [ 192.474213] Enabling wake83
                          [ 192.474222] Enabling wake29
                          [ 192.486471] Enabling wake76
                          [ 192.486473] Enabling wake77
                          [ 192.486475] Enabling wake78
                          [ 192.486477] Enabling wake79
                          [ 192.486479] Enabling wake80
                          [ 192.486481] Enabling wake81
                          [ 192.486483] Enabling wake82
                          [ 192.486520] Enabling wake73
                          [ 192.555437] Enabling wake71
                          [ 192.587463] CPU3: shutdown
                          [ 192.619451] CPU4: shutdown
                          [ 192.647445] CPU5: shutdown
                          [ 192.652403] Entered SC7
                          [ 192.652403] Exited SC7
                          [ 192.658275] CPU3 is up
                          [ 192.664019] CPU4 is up
                          [ 192.669812] CPU5 is up
                          capture channel
                          root@hello:/dev#
                          • H Offline
                            hello @hello
                            @hello
                            关于这个提供下下载的链接吧?
                            下载来源如下:
                            这个不是最新的吗?
                            另外使用新的dtb做法是直接拷贝覆盖吧?可要烧写步骤呀?
                            • H Offline
                              hello @hello
                              @hello
                              下载如下的dtb
                              烧写更新完成后发现摄像头sensor都检测不到了???
                                veye_xumm @hello
                                @hello
                                dmesg | grep veye
                                1. 请检测一下你的排线有没有插歪了的情况?
                                • H Offline
                                  hello @veye_xumm
                                    veye_xumm @hello
                                      veye_xumm @hello
                                      @hello 请问解决了吗?
                                      • H Offline
                                        hello @veye_xumm
                                        @hello 请问解决了吗?
                                        谢谢
                                          veye_xumm @hello
                                          • H Offline
                                            hello @veye_xumm
                                            刚试了很多次,不行,没效果
