    40 Posts 2 Posters 26.3k Views 1 Watching
    • H Offline
      hello @hello
      @hello
      继续文档3.7与3.8中的步骤操作:
      这些结果基本确认没问题吧?
      至此测试结果显示是否表面都OK呀?
        veye_xumm @hello
        @hello
        这里表面你检测到了一个camera
        • H Offline
          hello @veye_xumm
          • H Offline
            hello @hello
            @hello
            • H Offline
              hello @hello
              @hello
              进行4.2.1视频预览测试没有出现预览:
              • H Offline
                hello @hello
                @hello
                  veye_xumm @hello
                  现在你的系统检测到了。
                  • H Offline
                    hello @veye_xumm
                    • H Offline
                      hello @hello
                      @hello
                      New clock: GstSystemClock
                      Setting pipeline to READY ...
                      Setting pipeline to NULL ...
                      Freeing pipeline ...
                      root@hello:/dev# dmesg
                      [ 4.451868] CPU1: shutdown
                      [ 4.509501] CPU2: shutdown
                      [ 192.439657] Enabling wake24
                      [ 192.445718] Enabling wake53
                      [ 192.474213] Enabling wake83
                      [ 192.474222] Enabling wake29
                      [ 192.486471] Enabling wake76
                      [ 192.486473] Enabling wake77
                      [ 192.486475] Enabling wake78
                      [ 192.486477] Enabling wake79
                      [ 192.486479] Enabling wake80
                      [ 192.486481] Enabling wake81
                      [ 192.486483] Enabling wake82
                      [ 192.486520] Enabling wake73
                      [ 192.555437] Enabling wake71
                      [ 192.587463] CPU3: shutdown
                      [ 192.619451] CPU4: shutdown
                      [ 192.647445] CPU5: shutdown
                      [ 192.652403] Entered SC7
                      [ 192.652403] Exited SC7
                      [ 192.658275] CPU3 is up
                      [ 192.664019] CPU4 is up
                      [ 192.669812] CPU5 is up
                      capture channel
                      root@hello:/dev#
                      • H Offline
                        hello @hello
                        @hello
                        关于这个提供下下载的链接吧?
                        下载来源如下:
                        这个不是最新的吗?
                        另外使用新的dtb做法是直接拷贝覆盖吧?可要烧写步骤呀?
                        • H Offline
                          hello @hello
                          @hello
                          下载如下的dtb
                          烧写更新完成后发现摄像头sensor都检测不到了???
                            veye_xumm @hello
                            @hello
                            dmesg | grep veye
                            1. 请检测一下你的排线有没有插歪了的情况?
                            • H Offline
                              hello @veye_xumm
                                veye_xumm @hello
                                  veye_xumm @hello
                                  @hello 请问解决了吗?
                                  • H Offline
                                    hello @veye_xumm
                                    @hello 请问解决了吗?
                                    谢谢
                                      veye_xumm @hello
                                      • H Offline
                                        hello @veye_xumm
                                        刚试了很多次,不行,没效果
                                          veye_xumm @hello
                                          @hello
                                          你在终端杀掉gst-launch-1.0进程也是可以的
                                          • H Offline
                                            hello @veye_xumm
                                            @hello
                                            现在全屏都是预览的摄像头画面,退不出来,进不了终端
